20 Most Recent
Cadkey Corp CADKEY Version 6 Questions & Answers
Error accessing invalid language directory when
I got the invalid language error recently rescuing a copy of CADKEY 19
from an old WIndows 2k server for an engineer where I work.
I eventually was able to get rid of the error message by searching for
the string CK19 in regedit and altering keys with invalid paths to them
from the previous install.
CADKEY 19 seems to store a lot of static paths in the Windows registry, I had to update at least a dozen or so.
Using the Find Next feature with regedit made finding the keys and updating them purty easy.
Error accessing valid language directory
I have tried to install CADKEY 97 in a Windows 7
yes can be, just follow these steps:
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility".
This will allow you to choose on what type operating system your program
will run. Just reply back if it still doesn't work.:D rate and vote
for me:))
CADKEY 97
I had a similar problem trying to run under Windows XP and 2000 Pro.
I deleted the file named opengl32.dll from the Cadkey directory and now everything works fine.
By the way, Cadkey would load up and it seemed to be OK until I needed to type anything in, then it would make a warning sound and ignored the key strokes.
I hope this helps and works for you.
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
