20 Most Recent Kenmore 22 cu. ft. TRIO French Door Bottom Freezer Refrigerator Questions & Answers
2answers
Why has my kenmore elite trio refrigerator started to intermittently started to chime
Hi! I am having this exact problem also. The best answer I have been able to discover is that it is related to the freezing up of the internal water tube that drains the fridge compartment into the freezer section. In addition, a pool of water freezes on the interior floor of my freezer and has to be manually chipped up and removed. I did try to unload the freezer and defrost it thoroughly, but it still happens and has to be chipped each week. I am still seeking a solution, but at least I can make the chiming stop by locking the temperature via the button on the front panel. Best wishes. If you discover a better or final soln, please post. I will do so as well.. Regards.
8/11/2015 4:51:25 AM • Kenmore 22 cu.... • Answered on Aug 11, 2015
Model 795.75544401 This fridge makes a irregular
i found a manual online that can help you diagnose and fix things http://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
9/26/2014 8:42:31 PM • Kenmore 22 cu.... • Answered on Sep 26, 2014
How do I get the open door chime to stop on Kenmore Fridge?
I had this problem also. My problem was that the drainage tube that keeps the refrigerator compartment dry was plugged up with the foil backing used in the freezer compartment. This foil backing is used to line the closed cell foam which insulates the defrost heat fins from coming in contact with the plastic back panel. It took a service call from a local repairman two times to unplug the line. We peeled off the foil lining which was the source of the plug. This solution stopped the "door open"/"instant freeze" cycle sound. My fridge is about 6 years old. Hope this helps. Best wishes!
7/23/2014 5:26:55 AM • Kenmore 22 cu.... • Answered on Jul 23, 2014
How do I take KENMORE ELITE TRIO 596.75533400 out of demo mode?
Try pressing ultra ice and home while the refrigerator door is opened,or ultra ice and the refrigerator pad with the freezer opened. Hold for five seconds. Hope that works.
6/13/2014 1:34:55 AM • Kenmore 22 cu.... • Answered on Jun 13, 2014
Kenmore Trio Elite Refrigerator (Model 596.76583601) Won't Cool, Freezer is Fine
the coil needs to be defrosted or the defrost timer is bad also go to sears.com and you can download a manual :) hope i helped a bit
11/2/2013 6:19:44 PM • Kenmore 22 cu.... • Answered on Nov 02, 2013
Fridge is cold, freezer not working and making a clicking sound
check your vents in the freezer they may be blocked??
11/2/2013 6:09:04 PM • Kenmore 22 cu.... • Answered on Nov 02, 2013
Kenmore chest freezer cubic ft 253.16082108
19.7 cu. ft.
Kenmore 1608 - Elite 19.7 cu. Ft. Chest Freezer Use And ...
ManualsLib https://www.manualslib.com > manual > Kenmore-1608... View and Download Kenmore 1608 - Elite 19.7 cu. Ft. Chest Freezer use and care manual online. Use and Care Guide. 1608 - Elite 19.7 cu. Ft. Chest Freezer ..
4/10/2024 8:08:12 PM • Kenmore Freezers • Answered on Apr 10, 2024
2answers
Error code b on kenmore chest freezer
LOW / NO BATTERY ALARM The Low/No battery alarm will activate when the power level of the battery becomes low. The display will alternate between "b" (Battery, See figure 8) and the cabinet temperature, the red alarm light will become illuminated and the control panel will beep every five seconds. To stop the audible alarm (beep), press the "ALARM RESET" button. The red alarm light will remain on and the display will continue to flash until a new battery is installed. This same alarm will activate if there is no battery installed
2/18/2024 3:02:00 PM • Kenmore Freezers • Answered on Feb 18, 2024
Kenmore Upright Freezer Model #970180021 WB3285869Serial # I unplugged my freezer,plugged back said power interruption, I hit several buttons, Now flashing off, nothing else on panel lit up,thaw
try unplugging it and leaving it unplugged for a while. 15 minutes maybe? Leave door closed so it stays relatively cold. It should reset the unit.
2/8/2024 3:29:33 PM • Kenmore Freezers • Answered on Feb 08, 2024
2answers
Kenmore upright freezer. The alarm keeps going off?
The light may be staying on and creating heat, or the unit thinks the door is still open. Or the door seal is worn and is letting cold out. Or It needs gas. Have you put a thermometer inside to check the temperature? It should be 0'F +/- 2'. https://www.google.com/search?q=Kenmore+upright+freezer.+The+alarm+keeps+going+off ..
1/20/2024 10:41:55 AM • Kenmore Freezers • Answered on Jan 20, 2024
3answers
Kenmore Elite 25326082101 freezer. The FF sign is on and the Reset is lit. Freezer is not working. What can I do?
Question edited for full 'make model (what it is). Question moved to Maker category. 'FF' is Fast Freeze. Do a Power Reset. Disconnect from the mains for 5 minutes and plug back in. If that doesn't fix it, you will need a service call. It may have leaked refrigerant gas.
Kenmore Elite 25326082101 upright freezer manual
https://www.searspartsdirect.com > manual > kenmore-... Download the manual for model Kenmore Elite 25326082101 upright freezer. Sears Parts Direct has parts, manuals & part diagrams for all types of repair ...
10/30/2023 1:29:32 PM • Kenmore Freezers • Answered on Oct 30, 2023
2answers
My kenmore upright freezer has frozen water at the bottom and is leaking frozen at the top also. how and I fix it
It sounds like you might be dealing with a defrost drain issue or a problem with the freezer's door seal. Try defrosting the freezer and clearing any ice buildup, then check the door seal for any gaps or damage. If the problem persists, you may need to consult the user manual or contact a professional appliance repair service for assistance.
8/18/2023 8:36:22 AM • Kenmore Freezers • Answered on Aug 18, 2023
2answers
I have a Kenmore upright freezer that keeps saying "Power loss and Door Ajar''
What happened when kenmore upright freeze is not freeze and then temperature is lower
4/21/2023 9:16:47 PM • Kenmore Freezers • Answered on Apr 21, 2023
I have a kenmore model 970-254291 freezer. It runs all the time and has recently stopped freezing new foods. Could this be corrected by recharging the r131a?
dont know --what is r131a doesnt exist --- is it low on freon -has someone tapped a line in the past ---your system is a closed /sealed system that only needs freon if someone damages a line/component causing leak --yours can be any thing fron dirty condenser--failing thermostat--compressor or fan[s]
3/5/2023 6:55:37 PM • Kenmore Freezers • Answered on Mar 05, 2023
Where is the 9V battery located on a Kenmore upright freezer model 970
The location of the 9V battery on a Kenmore upright freezer model 970 can vary depending on the specific model and design. However, in general, the 9V battery is typically located in the control panel or on the back of the freezer near the compressor. You may need to consult the freezer's manual or contact Kenmore customer support for more specific information regarding your model.
2/14/2023 8:17:26 AM • Kenmore Freezers • Answered on Feb 14, 2023
Freezer shuts off when door is opened. Why does it do this?
The alarm and the temperature senor are both broken and need to be replaced for your freezer.
1/12/2023 12:40:02 PM • Kenmore Freezers • Answered on Jan 12, 2023
Kenmore 25322040510 upright freezer. We have model 253.22040510. Need manual please.
Question edited to add full 'make model (what it is)'.It may need a refrigerant gas top up. You need a service call.Kenmore 253.22040 SERIES Manuals - ManualsLibhttps://www.manualslib.com > ... > FreezerManuals and User Guides for Kenmore 253.22040 SERIES. We have 1 Kenmore 253.22040 SERIES manual available for free PDF download: Use & Care Manual ยท 2. English...
11/10/2022 9:30:50 PM • Kenmore Freezers • Answered on Nov 10, 2022
Can a kenmore chest freezer model 253.16502101 also run as a fridge?
No, only a select few catering appliances can be a fridge or a freezer depending on the temperature setting. Yours is a freezer. https://www.google.com/search?q=kenmore+chest+freezer+253.16502101+specs ..
10/12/2022 4:25:51 PM • Kenmore Freezers • Answered on Oct 12, 2022
Kenmore 22 cu. ft. TRIO French Door Bottom Freezer Refrigerator Logo
9 questions posted
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Freezers
  • Kenmore Freezers
Most Popular Question
  • Freezers
