20 Most Recent Everest Refrigeration ETWF2 - Undercounter Freezer, two-section, 18 c" Questions & Answers
0answers
STAY IN DEFROST MODE
Hello Santiago; My name is Peter. I am a retired field service refrigeration technician. In the defrost mode everything shuts down with the exception of the light. So, lets trip the defrost timer and get your freezer running. You did not provide a model number which is located on a label on the inside liner wall near the top. Your defrost timer may be part of your control board. Let's assume it is not. In the lower back left hand corner of you unit the is a metal plate with a small slotted shaft. With a large flat head screw driver turn the shaft clockwise on click at a time until your unit starts up. You must do the same thing every 12 hours to turn it off for 30 minutes to allow for defrost until the timer is replaced is replaced. 25570632-zjnlddqc4npjcfhwullt2vwq-1-0.jpg Note the round on the left. Go into the following web site, put in your model number. Select the diagram with the defrost timer. Search the internet with the part number shown Water Filters Lawn Garden Appliance Parts
3/14/2015 9:34:59 PM • Everest... • Answered on Mar 14, 2015
0answers
Esf1 error code e0
Be the first to answer 1/31/2014 3:36:05 AM • Everest... • Posted on Jan 31, 2014Be the first to answer
0answers
0answers
0answers
0answers
ERROR CODE E-3
Be the first to answer 11/15/2013 5:13:19 PM • Everest... • Posted on Nov 15, 2013Be the first to answer
0answers
ERROE CODE ER-3
Be the first to answer 11/15/2013 5:10:25 PM • Everest... • Posted on Nov 15, 2013Be the first to answer
Everest esf1 error 3
you try it again.
3/26/2013 2:43:21 PM • Everest... • Answered on Mar 26, 2013
Everest freezer esf1 error 3
I think that code is a mechanical error code. Not sure. Call the mfr and see what they say. You can google the code and model number and perhaps get it there.
2/25/2013 2:10:54 AM • Everest... • Answered on Feb 25, 2013
3answers
What should refrigerant gauges read when charging
Depends on what kind of refrigerant its works, if is an old unit probably is charged with R12 or R22 newer ones work with R404 ;for R12 presures should be around 20psi on the low side and 160 on the high side ,for R22 about 60 and 250 and for R404 50 and 350 ;you have to look at the condensing unit tag to find out what type of freon its uses ,or look at the expansion valve at the evaporator coil.
11/24/2012 5:27:16 PM • Everest... • Answered on Nov 24, 2012
0answers
3-door undercounter refrigertor worktop surface
the coils that deliver the cold air are building up condensation. anything that gets cold in the outside should be insulated so as to reduce condensation. hope this helps
9/15/2009 5:08:39 AM • Everest... • Answered on Sep 15, 2009
Freezer with loose red and blue cables
All question need full 'make model (what it is)', first 3 words. Google make model wiring diagram. Brown or Red is normally power and blue is return. https://www.google.com/search?q=Freezer+with+loose+red+and+blue+cables ..
4/22/2024 11:19:39 PM • Freezers • Answered 3 days ago
How do I remove shelves if they are attached to tubes connected to the back inside of the upright freezer
you do not leave them alone they may have refrigerant flowing through them. look in your owners manual/instructions for more info.
4/14/2024 10:55:01 PM • Freezers • Answered on Apr 14, 2024
Norfrost C6AEW Chest Freezer. Wiring help please.
Question edited for clarity and add CAPS. It seems to be a common occurrence on that model due to bad design. https://www.fixya.com/support/t17110008-norfrost_c6aew_chest_freezer_compressor Norfrost is owned by Ebac. Contact their customer service. https://www.johnogroat-journal.co.uk/news/caithness-freezer-name-lives-on-in-england-170710/ https://www.ebac.com/support/customer-service Another way would be to study the wiring as it is pretty standard. The video may help. https://www.google.com/search?q=freezer+wiring+diagram You may be able to freeze this video to note the wiring, although this only shows the thermostat wiring and is a bit fuzzy. Also an refrigeration appliance technician would know the wiring by heart and take 20 minutes maximum to work it out.
2/11/2024 5:45:01 PM • Freezers • Answered on Feb 11, 2024
2answers
Norfrost c6aew chest freezer compressor wiring
Hey. I dont suppose you figured out where the wires went all all? I've done the same thing ???? img-20240210-wa0019-hnmqxmichaytgjvoydy3hl3m-d-0.jpg img-20240210-wa0018-hnmqxmichaytgjvoydy3hl3m-d-1.jpg img-20240210-wa0020-hnmqxmichaytgjvoydy3hl3m-d-2.jpg
2/11/2024 12:01:33 PM • Freezers • Answered on Feb 11, 2024
Tappan TFC13M0AW1 Chest Freezer. What part should I replace?
Question edited to add maker! All questions need 'make model (what it is) as first three words. That is an overheating fault. Replace the fluff with no fluff. Make sure the condenser coils are free of dust and there is good airflow Or It is low on refrigerant gas and you need a service tech.. ..
2/3/2024 5:25:13 AM • Freezers • Answered on Feb 03, 2024
Everest Refrigeration ETWF2 - Undercounter Freezer, two-section, 18 c" Logo
0 questions posted
Top Everest Refrigeration Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you an Everest Refrigeration Freezer Expert? Answer questions, earn points and help others
View Most Popular
  • Everest Refrigeration Freezers
Most Popular Question
everest freezer esf1 error 3
  • Freezers
