20 Most Recent Kenwood Kmix Kmx50 Stand Mixer, White Questions & Answers
Kenwood Kmix KMX50 stand mixer 500 watt speed control not working. Accelerates and drops speed itself.
Question edited for clarity. Question moved from Cars and Trucks to model category. The OP, George supplies the answer. Update solved: problem was the tiny speed control sensor mounted above on the motor with three cables.
1/10/2023 6:30:43 PM • Kenwood Kmix... • Answered on Jan 10, 2023
I have a kenwood KMx 50 mixer & it has a speed
KMX50 would start and accelerate to high speed, then slow down some with fairly erratic speed. I tried changing the triac on the main speed control board, then also the whole board (£45). It made no difference. The only other component I realised it might be was the speed control board which is on the rear end of the motor under the main cover (I found this component on a site selling Kenwood parts, and was where I got the main board from, which is how I know it's speed control). When I inspected it I found two of the terminals broken. You had to look very closely to see they were broken. It's a poor design as the three legs of the terminals are quite long, and very thin, so on high speed when kneading there is much vibration, which is why I suspect the terminals broke. I cut them back just enough to resolder. The component isn't quite fully inside the sensor wheel on the motor shaft, but it still picks up sufficient signal to control the speed and now works fine. Haven't tried it under load yet, but no reason to think it won't work correctly. So check this before ordering a £45 board!
5/16/2019 1:50:55 PM • Kenwood Kmix... • Answered on May 16, 2019
My dough hook is stuck in my K mix kmx50.
yes the dough hook is a firm fit on those
Instruction Book KMX50, KMX59 English - Kenwood
www.kenwoodworld.com/.../Instruction-Manuals/kMix.../kMix.../18362iss2%20KMX..
4/29/2017 4:53:13 AM • Kenwood Kmix... • Answered on Apr 29, 2017
How do I take the gearbox out of my krnwood kmix
Hello Carol Wink, Here is a link to your Kenwood Mixer operating Manual. Everything is in there. You can View it, Download it or Save it to your PC. Good Luck! JP Kenwood KMX50 series Instructions Manual
7/16/2015 10:26:35 PM • Kenwood Kmix... • Answered on Jul 16, 2015
0answers
0answers
Kmix kmx50
Be the first to answer 2/27/2013 3:31:55 AM • Kenwood Kmix... • Posted on Feb 27, 2013Be the first to answer
Where can I get a replacement parts for kenwood km632?
If in the UK try espares; https://www.espares.co.uk/search/mo2748942/kenwood/blenders---mixers---juicers/km631-major-silver-+-at337 They may ship abroad ... I don't know, I am UK based.
12/19/2023 7:50:24 AM • Kenwood Food... • Answered on Dec 19, 2023
My kenwood multipro 910 food processor not working
Check the power supply: Ensure that the food processor is properly plugged into a functioning power outlet. Sometimes, a loose connection or a tripped circuit breaker can cause power issues.
Safety interlock system: The Kenwood Multipro 910 food processor usually has a safety interlock system that ensures all parts are properly assembled before it can start. Check if all the components, such as the bowl, lid, and blade, are correctly locked into place. If any of the parts are not properly assembled, the food processor may not work.
Motor overload protection: If you have been using the food processor for an extended period or with heavy ingredients, the motor may have overheated and triggered the overload protection mechanism. In this case, you will need to allow the motor to cool down for some time before it can restart.
Fuse or circuit breaker: Some food processors have a built-in fuse or circuit breaker that protects the motor from electrical surges. Check if your food processor has a fuse and ensure that it is intact. If it has a circuit breaker, reset it if necessary.
Mechanical issues: If none of the above steps resolve the problem, there might be a mechanical issue with the food processor. It could be a faulty motor, broken wiring, or a malfunctioning switch. In such cases, it is advisable to contact the Kenwood customer support or take the appliance to an authorized service center for repair.
7/16/2023 12:10:20 PM • Kenwood Food... • Answered on Jul 16, 2023
Hi, I have an old kenwood chef a701a with 2 tube like capacitors. Do you know what I can replace them with and if I need 2 capacitors.I know one is 0.1 mf and the other is 0.01mf.Thanks
You need to contact an electronic component supplier, there are many on line, they can answer that question for you.
6/24/2023 9:07:24 AM • Kenwood Food... • Answered on Jun 24, 2023
2answers
Kenwood Chef Premier can run at all speeds for the first few seconds. Then it runs slower and you can tell by the sound.
It sounds like there may be an issue with the motor in your Kenwood Chef Premier mixer. This could be caused by a variety of factors, such as a malfunctioning motor, a problem with the drive belt or gears, or an issue with the electrical components of the mixer. To troubleshoot the problem, you may want to try cleaning and lubricating the drive belt and gears, as well as checking the electrical connections and fuses.
1/8/2023 6:02:28 AM • Kenwood Food... • Answered on Jan 08, 2023
2answers
Kenwood kmix doesn't start
Help in the link including from Kenwood themselves. It is likely to be the selector, the control board or the motor. Take it in for Dealer Service. https://www.google.com/search?q=Kenwood+kmix+doesn%27t+start ..
12/8/2022 4:10:34 AM • Kenwood Food... • Answered on Dec 08, 2022
3answers
Circuit/wiring diagram for KENWOOD CHEF - Model A701A
BRG1 Please can you also email this to me
mal at speciss.co.zw
5/29/2022 4:38:44 AM • Kenwood Food... • Answered on May 29, 2022
Is is worth repairing a Kenwood Prospero stand mixer km24?
If you have a multi meter check the box caps and resistors for KM 2XX series then replace it whenever required. Some may differ in values like 0.15uF 275x2, 0.33uF 275X2 or 0.47uF 275X2 then resistors may also differ with different models but common to have 1.1k ohms 2watts. Also if caps are open it is good to check the 600V triac and replace it when giving out lower output. I also advise to clean the commutator esp when is is sparking a lot, you may use light sanding and clean it after. Check also if the tachometer is good, there is a resistor-like-coil hidden under a plastic tab with 2 wires. This gives feedback and via a magnet attached to the shaft. Check the motor brush if it is good or worn out. Lastly check all the switches because if one of them is not working properly you wont be able to let the motor run.
3/15/2022 9:48:12 AM • Kenwood Food... • Answered on Mar 15, 2022
Kenwood Kmix Kmx50 Stand Mixer, White Logo
9 questions posted
Top Kenwood Food Mixers Experts
vince
Ngoro
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
Kenwood Food Mixers
  • Kenwood Food Mixers
Most Popular Question
kmix kmx50 stand mixer 500w speed
  • Food Mixers
