20 Most Recent
Belkin (54G F5D7230UK4) Wireless Router Questions & Answers
How do I rename my
Please open the configuration page of your router by typing your router's IP address on a browser's address bar. Router's IP address is the default gateway when you check the IP address on the command prompt. As soon as you are on the login page, type the user name and password. Look for the wireless settings tab. SSID is the router's wireless network name. Replace the SSID of the name you want for your wireless network and apply the changes.
For some reason I get
Then someone has changed your password, that is the only way this message would show up.
How do I lock my Belkin wireless router?
You can lock your router by setting a password to access it. This is done in your router setup, in the Wireless area. I prefer WPA-PSK [TKIP] for the ease of setup and password selections. This should keep unwanted access to your wireless signal.
I secured my wireless a few years ago and forgot
You can reset the device to the default factory settings by holding down the reset button for 7 seconds. The default password is blank.
Now you can log into the router using an Ethernet cable, the default IP is 192.168.2.1.
I want to secure my
Access point configuration
1. Open a Web Browser
2. In the address bar type the IP address of your access point.
Note: By default the IP address is 192.168.2.254
3. Click on Security in the left hand column under Wireless
4. Enter your password if any and click Submit
5. Select WPA-PSK (no server) from the Security Mode section
6. Enter your Pre-shared Key
Note: You can mask your Pre-shared Key by selecting Obscure PSK
7. Click on Apply Changes
Network adapter configuration
1. Go to Start and click on Control Panel.
2. Control Panel window will appear. Double click on Network Connections.
3. Network Connections window will appear. Right click correct Wireless Network Connection by identifying correct wireless network adapter and click View Available Wireless Networks.
4. Wireless Network Connection window will appear. Select the network you wish to connect and click Connect.
5. The should now be security-enabled.
6. Enter the WPA-PSK network key you set up in the router as above.
7. If all goes well, you will connect to wireless network at last.
Have belkin _60 router for
Easiest way to change your wireless password would be to log-in to the router and configure it from there. To do this you need to a few things:
- Connect your laptop to your Belkin router with an Ethernet cable. This allows a direct connection to the router so we can log-in.
- Find your routers IP address. To do this, it really depends on what operating system you're on. If it's windows XP/Vista/7; you'll do this by going to command prompt. Click the Start button then go to All Programs on the bottom left side, click on Accessories, and from within there you'll see a black icon called Command Prompt. Open that up and type this in: ipconfig You'll get something like this:Look for the Default Gateway under Ethernet Adapter Local Area Connection.
- Open a Browser and type in that Default Gateway in to the address bar at the top (where you normally type in www.whatever.com..ect), For example, for mine, I'd open up my browser and type in 192.168.0.1 and hit enter.
- After you do that you should be taken to your router's configuration menus. For Belkin's, it's usually on the left hand side menu under Wireless and then Security. **If you're prompted for a password just leave it blank and hit submit. Also under the Wireless section on the left you can change your SSID or Network Name to something you see fit. To do that just click on Channel and SSID and change the SSID to whatever you like. Just be sure to hit Apply Changes at the bottom and the router should give you some kind of notification saying it working and when it's done.
**If you're prompted for a password and leaving it blank doesn't work, chances are you'll need to do a reset on the router so it goes back to default settings. To do this just use the small pin-hole sized reset button on back of the router, it should be where all the cables plug in to it. Use a paperclip or ball-point pen and hold it in for about 10-20sec and let go.
I have bought a new laptop and are not able to
The wireless router makes computers that already have an internet connection share signal with another computer. For example, the new computer would still not have an internet connectin. Power on each devices of computer and routers to make the next process achievable. For example, the router searches to acquire any available networks either as locall to internetworked diaplayable on the wireless area logo on the computer settings. Once recognised, local or network signals require request to below as new computer device setup. Usually another computer entity has to be notified of intent to capture signals with new ware. Contacting a wireless network provider guarantees the signals connectivity amongs several resources that makes an experince between devices achieveble. Locate either telephone network establishments to ascertain the requriements to establsihing a new network of devices. Prior to contact the network establishment, ascertain the computer devices brand, pertinent details that would make estabsihement effective.
My network is unsecured how
you can log in to your router by using trhe default IP address provided.. and look for the security option on the home page... you can type your default IP address on your browser but be sure that your pc and router is connected and switched on....and you will be ask for the default username that the owners manual provided...
Password has been changed
I got this same error on my Belkin N150 router.
I called Belkin Tech Support (877-736-5771) and they had me uninstall the Belkin Setup Program via Add/Remove Programs, and now everything is fine.
I'm not saying this will solve your problem -- you should probably call Belkin Tech Support just to be sure.
Trying to add an additional computer to the
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network on all your computers ( Wireless )
Let me know if it works
Regards
TOM
Hya#was wondering could you tell
you need to login the router in the address bar... the address depends on the make of the router, typically it's 192.168.1.1 for linksys. I would google Belkin (model#) password. and it will give your default username and password for your specific router. If somebody has already taken over your router just unplug it for a minute or press the reset button on the back. Resetting the power on it puts it back into default login, so now you want to change the administrator password after you login the router from the web address bar.
How do you set up a new wireless connection. Was
Step 14 : Now Scan and connect to this network ( Wireless )
Belkin router my password has been changed
Are you speaking about the password of the router or the password of the wireless network ?
If you don't know the password of the router , then you will need to reset the router and use the default password of the router.
Once you reset the router, you will need to reconfigure it.
If you are looking for the wireless password, you can find it on the set up page of the router.
You will need to open the set up page of the router.
Click here for step by step instructions
I cannot connect Amazon Kindle to my router. The
Are you using WEP 1 or WEP2 on your router? It may be that the Kindle doesn't like one or the other.
Also check to make sure that when you put the key in, you are following the case of the key, as they are case sensitive.
