20 Most Recent
Waring Wwo100bj Pro Wwo100pc Professional Cordless Wine Opener Questions & Answers
Weak battery
then the rechargeable battery is dead. take it to Batteries Plus to have them replace it
Remove motor from 1940s F-2 Waring blender
If you think you need to replace it, first make sure you can get the part.
then look for a parts breakdown at an online parts store. If that doesn't help you will have to hunt and peck to figure it out. Do not be too aggressive, though after all these years things will be stuck.
How to replace waring blender 028538 drive coupling
Check and see if your blender was made in China.
If so, the chances are really slim for a finding parts for a fix.
If it was made in the USA, try "e-bay" for parts.
If you need a parts list, you will need to find one first.
Also, type Waring Blender into your search engine on your computer, to see if a dealer or repair place has a web-site.
God bless your efforts.
Leaks at the bottom of the glass holder
I'm no expert but in my experience if it leaking at the bottom then either the jar /carafe has a few chips or cracks around the hole in the bottom that the blade fits through and in that case you need to replace the jar and your blade assembly may still be good and can be moved to a new jar/carafe. Or the blade assembly has come loose a little and need to be tightened or some the washers (usually the rubber ones) have worn out and need to be replaced. There's plenty of explanation here at amazon and else where on how to replace the assembly blade, move it to a new jar and tighten it down, etc. Hope this helps!
Waring blender switch wiring
most blenders throttle the power by using different taps inside the motor winding themselfs ., the switch just selects what tap to use and applies power to that winding , just three windings can produce multi speeds if used in combinations sorry no easy fix for switchs other than to make sure theres no food down inside them , i use a good electrical contact spray (CRC) down in them to make sure
