20 Most Recent
Sony Acid Music Studio 7 for PC (MSAMS7000) Questions & Answers
No serial numbers
If you are using a trial version from the software producer you will not need a serial code, however beyond the trial period you will need to either purchase the actual CD or Download from their site and then they provide you with your own unique code that unlocks the program allowing complete functionality of the software.
if you find a great program as Acid Studio it is very much worth paying for the legal rights for usage.
I use the particular studio software and the low cost is a fantastic bargain!
Sony acid 7.0
You need to contact the manufacturer if you've lost your serial number. Provide proof of purchase and they may give it to you. Or, look inside the box or on the sleeve when you purchased your program.
How to get serial number
Good effort.. you wont get cracks or serials here. If you have bought a serial, then just email Sony and it will be resent to you.
SONY CX330 camera shutting down
Why do they need to be turned on all the time? If your using them as security cameras they are not designed for that job. The 330 could be overheating because of the constant use. Some cameras have a built in 'Overheat' switch which could be switching it off.
These cameras are designed for short periods of use, recording things like parties and holiday trips. How old are these handycams? These do get old and the technology in them can wear out if in constant use.
Sony cfd-s70 Will Not Read CDs
There are a few possible causes for a Sony CFD-S70 CD player not reading CDs. Some possible issues include:
- Dirty or damaged CD: Make sure the CD is clean and free of scratches or damage.
- Dirty lens: The lens that reads the CD may be dirty or dusty. A cleaning disc can be used to clean the lens, or you can use a soft, dry cloth to gently wipe it clean.
- Faulty lens: If the lens is faulty, it may need to be replaced.
- Faulty CD mechanism: If the CD mechanism is not working properly, it may need to be repaired or replaced.
- Power Supply Problem: Make sure the power supply is connected and the power outlet is working.
- Firmware issue: A firmware issue could prevent the CD player from reading CDs. You should check the Sony website to see if there are any firmware updates available for your specific model.
If the problem persists after trying these suggestions, it is recommended to take the device to a professional repair service or the nearest Sony Service center.
