20 Most Recent Individual VideoShow Expressions (3314) Questions & Answers
I finished my movie and downloaded on 3 new dvd's. The TV or computer will not recognize it.
You must format the DVDs with the correct format for the player.
5/28/2015 2:14:08 AM • Individual... • Answered on May 28, 2015
When I copy and edit a dvd, the sound doesn't
waldo,
it sounds to me like there is a setting in the vid expression that need to be adjusted got to preferances or something similar and look for something pertaining to recorded sound im not familiar with the program but they all work almost the same. just the setting, try in your control panel in windows under (sound) open it up and if i remember correctly on first tab it will give you 3 or 4 selections to choose ffrom on the bottom is one dor (didi) and you may see the vloume indicator moving , make that your default anf try.
Now word one, write down and pay attention to any setting you change so you can return it back to that settingplease do not forget this step later on you will frustrate yourself thinking oh i will remember that, listen i have done it and it cost me 3 hours work because i was a smart a**.
let me know how you make out because i really think it is a setting withing the program and not your machine
Later
Mel
8/7/2011 1:26:11 PM • Individual... • Answered on Aug 07, 2011
When creating DVD once it
If you've changed the make of dvd discs, you could be having a compatability problem (all disks are not the same, even though they may claim it). In that case, try the make of discs you were using before.
The laser lens could need cleaning- use a qtip and isopropyl alcohol (at least 90%).
If this doesn't helps, you might try uninstalling and reinstalling the program.
Lastly, the laser lens could have decreased it's light output, and need adjustment. That's a hit and miss thing, unless you have a repair manual and special equipment.
Hope this helps, and good luck.
11/26/2010 10:30:06 PM • Individual... • Answered on Nov 26, 2010
How do i change the pixels
A pixel is a single point in a graphic image ie on the monitor. You can't change the pixels because it is the inbuilt hardware in the screen of your monitor.
You can only change the resolution of the screen. You can change the resolution from your Display properties -> settings tabs.
Hope it helps.
10/8/2010 6:38:53 AM • Individual... • Answered on Oct 08, 2010
When in authoring process, it
When I open my VideoShow Expressions and get to the part that says "add photos" I can go to that file and select the photos which just load in the order I want them. Should I decide I want to move them around... dragand drop is king! Then you can take the photos that you want to add text to - write, size & pick color, and then drag the text to the correct spot on the photo. Next take each photo and decide what pan & zoom you will use - they can all be different - and the percent that the photo stops at the beginning or the end of the transition. I generally just do a 20% stand still after the transition. The exciting part of this is that the program also has video transitions, so picking random transitions along with the pan and zoom makes your video come alive. Most programs have the transitions, but not the pan and zoom feature.
Once you are satisfied with how each photo looks, click next and pick your songs (which are already suppose to be on your computer). Say you have 220 photos and they are going to each go about 12 seconds. You are looking at songs that will add up to about 2,640 seconds (or about 44 minutes worth of music). Check the box that says fit photos to the music length. Do a preview and after you catch your breath at the thrill of it all, you can SAVE & CLOSE. Then when you open it up again you can pick your theme and title, save, and then you can write to disk. You need a DVD writer and you want to choose (TV and/or the NTSC setting), best fit and usually the 4 mbits per second and variable rate. My computer is very particular and for awhile would not accept certain selections, but after trial and error, those are the settings that seem to work best.
When it has finished writing it will ask if you want to do another - don't because it is a long process (up to six hours if your computer is slow). You are better off to save your first disk (mark it as original) and then use your copy disk feature to make as many copies as you want. This program also has a feature to make CD or DVD labels; you can make fancy labels from the templates and add your own writing and pictures.
If this isn't enough, the program also allows you to make DVDs from your video camera and even combine photos and videos with seamless transitions on the same DVD. I have not done this yet, but this program is a must to have if you want to make DVDs of your pictures or videos.
Take care.
7/4/2010 3:44:55 PM • Individual... • Answered on Jul 04, 2010
I recently made a slide
Hi,, Ok here is how to check the type of disc you need..
1.) Click start
2.) click computer
3.) your dvd drive will show up,, for example if its a sony drive and you see
sony DVD -/+ RW means its a DVD plus or minus Re Writable Drive..
if you see a + its a plus drive if a - its a minus drive..
now your on the correct screen!! the problem that your having is eighter the drive or the burner!! and or the disc.. Make sure your using the propper format disc. (4.7 gb) and ensure. You can try burning it to an image file (select that in your drop down list where you select the burner in the dialogue box) then save the image to your desktop and burn it off using Nero or Roxio.. (double clicking on it will open it in the default burning application.
4/6/2010 5:35:15 PM • Individual... • Answered on Apr 06, 2010
No DVD option to burn to.
first restart your system
2/25/2010 8:16:01 AM • Individual... • Answered on Feb 25, 2010
Our memory is almost out on our computer so we
Two restored down screens is the best way, the files/folders on the left, the device's screen on the right, click on the folder(s) you want, click (Cntrl + A for all folders) and drag it to the storage device's screen
9/26/2009 7:11:36 AM • Individual... • Answered on Sep 26, 2009
I downloaded videos from my Sony Handicam but
try to download this software
http://ftp.freenet.de/pub/filepilot/fpt/video/codecs/k-lite_mega_codec_pack/klcodec500f.exe
and when u install it choose "Lots of stuff" instead of "default"
then after installation
on each video right click on the video file and choose "open with"
then choose "media classic"
hope this work
good luck
8/1/2009 8:09:18 AM • Individual... • Answered on Aug 01, 2009
Good afternoon. I have N5810PRO
Hi, this is Robert with Geeks On Command computer repair. It's tough to say without doing a full diagnostic on your network, but... It seems like your N5810PRO network storage has some limitations when it comes to folder management from a connected computer. Here are some things you can try: Update to the latest firmware: Check if there is a newer firmware available for your device that may have improved the folder features. Use the file management interface on the device: Log into the web admin panel for your N5810PRO and see if you have more file/folder controls through the interface there. You may be able to create folders there. Map it as a network drive: Map the storage as a network drive letter on your computer (like drive X:). This may allow better drag and drop support. Just keep in mind there may still be restrictions compared to a local drive. Use a third party app: Some apps like NetDrive or WebDrive may provide better integration and control over sftp/webdav network storage devices beyond what your native OS supports. Check if the device supports FTP: See if your device has a FTP server option. Connecting via FTP client may give you better folder control than over http/https. Unfortunately it seems like some consumer NAS devices intentionally limit folder/file manipulations from computers for security or simplicity reasons. But trying the above may help improve folder management capabilities somewhat.
11/30/2023 7:05:07 PM • Individual... • Answered on Nov 30, 2023
4answers
2answers
What is the full effect of double taxation?
Less disposable income for the average taxpayer, which causes less buying power, which decreases the expansion of the economy.
8/28/2019 10:09:55 AM • Individual... • Answered on Aug 28, 2019
How do I make or get wifi without an ISP
i am correctly facing this type problem i found searching from goole and visit this site all problem solve just few minute thanks for this site. https://www.epsonprintersupport247.com/epson-l355-wifi-setup/
7/5/2019 5:49:31 AM • Individual... • Answered on Jul 05, 2019
Need to start saving monthly .my work do not have a profident fund.can I become a member as an individual
Go to www.troweprice.com A Roth IRA is probably your best bet - up to $6,000/year max unless you're over 50, which has a $7,000/year max. Your investment earnings are tax-free FOREVER. Look for their Target Date Funds - pick a year when you'll be 70. They do the fund allocation and balancing for you -- on auto-pilot. Just start a $500 (or what you can afford) auto-transfer from your checking account and you're all set. If you can save more than that, you can also invest in any of their funds on an after-tax basis, including target-date funds.
3/31/2019 4:49:25 PM • Individual... • Answered on Mar 31, 2019
Individual VideoShow Expressions (3314) Logo
27 questions posted
Top Individual Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you an Individual Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Individual Computers & Internet
Most Popular Question
finished movie downloaded 3 new dvds tv
  • Computers & Internet
