20 Most Recent
Rug Doctor Mighty Pro X-3 Ready Pack Commercial Grade Deep Cleaner Questions & Answers
Rug doctor won't spray water
I had the same thing happen to mine. I looked at the hose in the water tank and the screen at the end if the hose was slimy and clogged. I took the screen off and cleaned it up, put everything back together and it works like new again. Only 2 screws and a screen.
11/16/2021 11:59:11 PM •
Rug Doctor...
Answered
on Nov 16, 2021
I have a rug doctor blue machine. It will not
Only two things can be wrong here, either the solution hose is plugged, kinked or undone from it's source, or the pump motor is not working. I'd try the hose first, if you can, take it off at the pump and then turn the machine on. If you get solution pumping out of the unit, then it's not the little pump motor and your problem is in the hose.
Which wire is the power wire on the jlt pump
post a picture of the wiring but hot is generally black neutral is generally white ground is always green sometimes they use red blue dark yelloow purple as hot so it is hard to say which color the unit uses there are only about 3 wires maybe a 4th if it has a seprate switch for the pump but the picture of the circut would answer my questions
