20 Most Recent Furuno 520 Ihd Adj In Hull F/ 6000 600l 582l 16&1850df Questions & Answers
2answers
Can not get clear reading of bottom when travellling over 9 knots
Your in hull ducer is getting turbulence. (in hull or not) A transducer will stop working is the tiniest cabitation or air bubble interferes. If possible, relocate the ducer. If you have a transom mounted ducer, try angling the leading edge up. This is a 90 % chance caused by turbulence on ducer. The other possibility, al;though remote is that you alternator or ignition system is interfering after a certain RPM on the motor.
Try first to manually gain the FCV620. You will always need to manual gain set the unit if you have an in hull ducer.
6/25/2013 3:38:20 AM • Furuno 520 Ihd... • Answered on Jun 25, 2013
2answers
How to program frequency 8113.5 on my Furuno FSS1503 Single Sideband Radio Telephone?
To program a specific frequency on the Furuno FSS1503 Single Sideband Radio Telephone, you can follow these steps:
  1. Press the Power button to turn on the radio.
  2. Press the Frequency button to select the desired frequency range (HF, MF, or VHF).
  3. Use the arrow keys to select the desired frequency (8113.5 kHz in this case).
  4. Press the Enter button to confirm the frequency selection.
If the frequency is not working, there may be other factors affecting the radio's performance, such as interference, atmospheric conditions, or a faulty antenna. It is recommended to use an antenna coupler or tuner to optimize the radio's performance and ensure proper transmission and reception. If you are still experiencing issues, you may need to consult a professional technician or the manufacturer's customer support for further assistance.
2/25/2023 5:04:49 PM • Furuno Boating • Answered on Feb 25, 2023
I got this message during Permits file upload in Licence window: AccessControl: Access denied: Failed to obtain permission from peers: Synchronization error: Cannot Connect to peer 192.168.31.2
Run as adminisrtator...right click on aplication,option run as adm or properties advanced or property personal
9/25/2022 6:36:40 AM • Furuno Boating • Answered on Sep 25, 2022
I have a Furuno 1721 MARK- 2 , Type RDP-098 with a RSB-0067 Scanner. What signal cable do I need and where could I find one. I would need a 15 to 20 meters in length.. Thanks
Sorry Dave. The links that Ngoro has provided CLEARLY state that the cable is no longer available from Furuno in the U.S. or Canada. His two additional comments come up 404. You MIGHT get lucky on Ebay or Craigslist. Sorry I couldn't have been of more assistance to you. -Steve Product Detail 008 428 590
7/30/2022 3:44:48 AM • Furuno Boating • Answered on Jul 30, 2022
Furuno screen upside down
New Installation? Check out the fix in the link. https://www.google.com/search?q=Furuno+screen+upside+down ..
6/13/2022 4:43:31 PM • Furuno Boating • Answered on Jun 13, 2022
FC5 585 picture is upside down
4/7/2022 10:43:34 AM • Furuno Boating • Answered on Apr 07, 2022
I need service manual book furuno fcv 620
The user manual is easy to find but they post warnings if you try to open it up and state you should contact an authorized repair facility or the factory. I could not find one.
10/2/2021 3:57:28 AM • Furuno Boating • Answered on Oct 02, 2021
Is the Furuno LS8000 3-D?
ask Furuno or a marine dealer .
4/20/2021 1:37:46 AM • Furuno Boating • Answered on Apr 20, 2021
I have a Furuno FS1550 marine transceiver and want to interface it to a SGC-230 / Barrett 911 autotuner. May I have the pin-outs and function of the socket marked coupler at the rear of the radio.
I have just had a quick look at the specs for both units you mention - you didn't say whether you are running a marine base station or it is on board a vessel? In either case I would advocate keeping both units as separate as possible and using a dedicated psu for the autotuner and so only the transceiver output is the only connection you need to make to the autotuner other than connection to the antenna and to a good earth or ground plane. I also suspect the autotuner is intended to be fitted close to the antenna as it is "fully weatherproofed"...
11/25/2020 8:51:04 AM • Furuno Boating • Answered on Nov 25, 2020
I need furuno ecdis password.. model FMD-3100
Web page for Furuno give contact information to request assistance. https://www.furunousa.com/en
6/5/2020 11:52:43 AM • Furuno Boating • Answered on Jun 05, 2020
How do you switch from Raster chart to Vector chart in the FURUNO FMD ECDIS?
Here is the link to the manual which explains everything in detail. https://www.furunousa.com/-/media/sites/furuno/document_library/documents/manuals/operation_manuals/fmd32003300_operators_manual.pdf Of course you have to have the vector charts that you want installed or ready to install on your system. Good luck.
9/13/2019 2:27:35 PM • Furuno Boating • Answered on Sep 13, 2019
Furuno 7000f screen is stretched and folded. Display is there but part of screen overlaying top part. Video is only problem!
Probably need to contact the manufacturer for support.
6/10/2019 7:45:33 PM • Furuno Boating • Answered on Jun 10, 2019
What does the alert number 031 indicate in furuno ecdis?
I do not know Furuno.
11/7/2018 4:18:46 AM • Furuno Boating • Answered on Nov 07, 2018
Where can i download a manual for 1. Furuno SSB
Search Results click here
10/11/2017 1:29:18 PM • Furuno Boating • Answered on Oct 11, 2017
Furuno 520 Ihd Adj In Hull F/ 6000 600l 582l 16&1850df Logo
1 questions posted
Top Furuno Boating Experts
ZJ Limited
ZJ Limited
jws1013
ROBERT GARCIA
ROBERT GARCIA
Are you a Furuno Boating Expert? Answer questions, earn points and help others
View Most Popular
Furuno Boating
  • Furuno Boating
Most Popular Question
not get clear reading bottom when
  • Boating
