20 Most Recent
Furuno 1650wf/Nt Gps/Chartplotter/Fishfinder Questions & Answers
My Furuno gp1650wf chartplotter is
Congratulations the device is within functionality. As a matter of fact devices without shark lense are least impactful. For example, the device may least capture images or receive data in realtime however provides accurate flight resources.
Unit will not power up
It is possible that their is a fuse inside the display. I would recommend sending the unit to a Furuno dealer to take a look at it. You can contact me:
[email protected]. We are a Premier Furuno Dealer that does bench repairs in house.
My furuno chartplotter is out about 2 km on the
Make sure your time offset is correct and also make sure you have not accidentally offset the chart. Also keep in mind that there are places in the charts that you can overzoom which can also cause this problem.
Furuno 1650wf keeps losing gps fix
Check your cable. Sometimes the cable connector goes bad and other times it's the connector on the inside of the unit. Get a dealer to check this one out. Try sending it to Mid-Shore Electronics in Maryland if you're in the U.S.
How to program frequency 8113.5 on my Furuno FSS1503 Single Sideband Radio Telephone?
To program a specific frequency on the Furuno FSS1503 Single Sideband Radio Telephone, you can follow these steps:
- Press the Power button to turn on the radio.
- Press the Frequency button to select the desired frequency range (HF, MF, or VHF).
- Use the arrow keys to select the desired frequency (8113.5 kHz in this case).
- Press the Enter button to confirm the frequency selection.
If the frequency is not working, there may be other factors affecting the radio's performance, such as interference, atmospheric conditions, or a faulty antenna. It is recommended to use an antenna coupler or tuner to optimize the radio's performance and ensure proper transmission and reception. If you are still experiencing issues, you may need to consult a professional technician or the manufacturer's customer support for further assistance.
I need service manual book furuno fcv 620
The user manual is easy to find but they post warnings if you try to open it up and state you should contact an authorized repair facility or the factory. I could not find one.
