I have a Lowrance LMS
Hi, well the best thing to do is to add suppressors to your spark plug leads, OR get Suppressive Spark Plugs, themselves, (Recomended) and Capacitors on ALL Positive Connections to Earth
I recommend , 0.1uF 500 V AC CERAMIC, or Axial Polyester Capacitors.
Capacitors DO NOT conduct DC, therefore, ONLY the AC "Hash" component of the signal is affected. the AC flows through, the capacitor, and then to earth.
Also make sure you Earth connections are good and robustly attached, to clean metal surfaces, and then cover with Petroleum Jelly.
You can get suppression Capacitors from almost any Car Electrical place or a Auto Electrician. They are easy to fit, and make a huge difference.
You need to do it, on the Coil, the Distributor and all spark plug leads too.
Another good thing to do as well, is to convert your car to a "Points-less distributor" Usually one can retro-fit a Sensor in place of the Points, this makes a remarkable difference. Of course some cars already have it.
Again with any thing that's using a Shielded Cable, (Coaxial Cable), then, add capacitors at each end, of the cable, put a Capacitor, from the "Shield" to Earth, at each end. Then any signals "Induced" into the "Shield" will again be routed to earth.
