20 Most Recent
Northstar Explorer 660 Gps/Chartplotter/Sounder Combo With Tm Transducer Questions & Answers
Trackfish 6600 stops and starts again by himself
Try a factory reset - that worked for me when my Northstar Explorer 660 stopped by itself again and again. You find this reset commando by pressing MENU twice and then under Systems menu, if I remember it correctly. There is also a RAM Clear commando. This is done by holding the MENU button pressed when the GPS is switched off. Keep it pressed while switchin on the GPS, still holding the button pressed until the RAM Clear menu appears. You will probably loose all waypoints etc. by doing this so try Factory Reset as your first alternative. Good Luck! // Jonas, Sweden
8/16/2011 9:00:29 AM •
Northstar...
Answered
on Aug 16, 2011
While on the water we've turned the unit off and
First check the cables supplying the unit from the jack connector behind the unit for continuity to the battery for a loose, corroded or broken wire before breaking the seal on the unit. Good luck.
1/28/2011 3:04:21 AM •
Northstar...
Answered
on Jan 28, 2011
Northstar explorer 650. Cannot get satellite
Unplug it for Few Minutes. Turn it Back On after few Minute. Is that Fixed the issue? Have you tried to Update the Firmware or You have Tried to Reset it ( Read Manual ).
Most of the time,if you are lucky you could get it worked.
99%, the Fault is usually the antenna being Failed. You need to send the Unit for Repair. Read the Below Link :-
http://www.sharc.net/gps_antenna_repair.htm
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
12/26/2009 3:57:37 PM •
Northstar...
Answered
on Dec 26, 2009
