20 Most Recent
Clymer Harley-Davidson Dyna FXD Evolution 1991-1998 Questions & Answers
No spark,no power to ignition module
Do you have power to the fuse? Sometimes fuses look good, but are actually bad. Check with volt-ohm meter. otherwise bad connections and or wire, corrosion causes a lot of bad behaviors, clean to bright metal for all connections and contacts. Again check with volt-ohm meter, or "indicator" light method.
4/11/2015 1:33:47 PM •
Clymer...
Answered
on Apr 11, 2015
How do i fix a vacuum line hose on a car that's been cut?
Alot depends on the type of hose. There are plastic hoses and rubber hoses. Generally you can use a smaller plastic connector to connect two rubber hoses together and visa versa, Make sure it is a snug fix. You could also use an adhesive to keep it together.
3/31/2024 3:39:13 PM •
Vacuums
Answered
on Mar 31, 2024
How to empty a etl vc-h3301 vacuum cleaner
How to open it to see if the fuse is blown. I removed the three screws I saw. I feel that there is another which prevents me from opening it in two. I looked under the tights, I removed the plate where the two buttons are located. I can't open it.
3/21/2024 4:57:04 PM •
Vacuums
Answered
on Mar 21, 2024
Kenmore Beltless Vacuum brush will not spin.
there is a reset button on the side of the lower base of the machine, plug in the unit turn on the switch to the brush and vacuum are both engaged hit the reset button, remember the roller will not engage when the handle is in the upright position, release the handle and your ready to go.let me know if that helped you . thanks renevacdoc
2/3/2024 5:49:33 PM •
Vacuums
Answered
on Feb 03, 2024
Red light comes on after charging my ergorapido
I had the same problem. Red light would come on after charging was complete. On investigation I found that there is a small gray wire that runs from the rear batteries to a large solder spot on the control board. Upon re-soldering this wire I got an additional 3 V of power and the red light does not come on anymore after it is charged. I can vacuum the whole house and then some and still not run the batteries down.
2/3/2024 6:53:13 AM •
Vacuums
Answered
on Feb 03, 2024
