Eclipse Car Audio & Video • Uploaded on Aug 26, 2013
If the woofer isn't moving significantly, try the following settings:
gain at highest (most sensitive) setting
crossover at highest frequency
subsonic filter at the lowest frequency
If those do nothing and you have a dual voice coil woofer, you may have one coil reversed. If you disconnect one voice coil and the woofer moves significantly more, check the polarity of all speaker wire connections.
Here's a brochure for the amp:
http://cartoys.com/cartoy/pdfs/eclipse_amp_manual.pdf
You're correct. this amp cannot be bridged to produce more power. It's minimum safe load is 4 ohms per channel. It's essentially two bridged amps in one chassis.
18 questions posted
143 Questions
124 Questions
71 Questions
28 Questions
21 Questions
