20 Most Recent
Roomba 415 Questions & Answers
My roomba 980 has an error10 left. So I purchased new module wheel inserted it and it's still saying error 10 left. HELP !
If your Roomba 980 is still displaying an error 10 (left wheel error) after installing a new module wheel, it could be due to a problem with the new module wheel or with another part of the vacuum. Here are a few things you can try to troubleshoot the problem:
- Make sure that the new module wheel is properly installed and seated in the vacuum.
- Check the connections between the module wheel and the vacuum's main board to make sure they are secure and not loose.
- Check the left wheel and the left wheel motor to make sure they are not damaged or malfunctioning.
- If the problem persists after trying these troubleshooting steps, you may need to take the vacuum to a repair center for further diagnosis and repair.
I hope this information is helpful! Let me know if you have any other questions.
What does err 1 mean on irobot roomba
Overview. Error one (1) means
your robot is on an obstacle or an uneven surface and a side wheel is stuck. If this is the case, lift your robot off the floor, place it in the center of the room, and restart the clean cycle. If this error occurred on a flat surface, check the wheels for obstructions.
Jul 22, 2021
Roomba®: Error 1 - iRobot support
My Roomba sat on charger but it kept saying Charge Roomba. I cleaned the 2 contacts on both charger and the Roomba. Now it's not saying anything. How can I tell if it's charging?
I'm far from a Roomba expert and only clicked on your question out of curiosity given my background and as there was a similar question earlier Id passed.
A little research... Roomba NiMh battery pack is 14.4 v full charge. NiMh charging is a bit complicated, suffice to say it will eventually go well over 16V.
I would expect the charging station to have an initial charge voltage in excess of 12.5V. What I don't know is if its always on or waits to see if a load (roomba) attaches and then turns on its output.
So if you measured the power, contacts on the charger with a voltmeter and you get better than 12V likely its good, but really need to know what the voltage is when Roomba (with nominal battery pack) is docked.
Its likely the battery pack in the Roomba has a bad cell and will need replaced. You could measure the battery voltage but likely its low from not taking a charge. If its 14+ then the charger is working and the Roomba is misreporting.
