20 Most Recent
Farenheit DVD-13 Car DVD Player Questions & Answers
Overhead car dvd player will play but will not eject the cd
Had the same problem and two audio repair techs told me that it was a matter of 'wear and tear' and would be more economical to replace the unit. Wasn't in a position to do that so modified a pair of tweezers by gluing rubber pads on the heads and gently pulled the disc out. Not the best work-through but it sufficed until I sold the car. The cushioned tweezers didn't damage the discs.
Farenheit car dvd install ?
Try Hokking the Yellow Memory wire to a 12 V supply. I should work. If you need the dvd to turn off automatically change your red 12 V to ignition.
Not sure what I need for audio
Try turning your stero to 88.7. I cannot figure out how to get the sound to come out through the jacks though. I plan on buying the IR headphones at somepoint, but I would like to be able to use the jacks in the meantime
When I hook up my
Welcome to Fixya
It is actually a safety feature of player that wont allow you to watch video while driving. If security happens even if you are park then there must be a problem somewhere. Try to check the parking wire if it is connected to
the radio ground. It should be connected to radio ground instead of the parking break ground.
Thank you for using Fixya! If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
