20 Most Recent
Sunbeam MR.COFFE 12CUP P/N/PAUSE,CHROM" Questions & Answers
I have a Sunbeam micro-glide
Make sure that the Iron is unplugged from the Mains socket. From a Paint shop / Hardware shop.get some Turpentine. Wet a soft cotton cloth with Turpentine and gently wipe the iron surface in a circular pattern. You might have to wet the cloth a few times and the color will come off.
After the color comes off wipe the teflon area with a liquid dish washer solution to remove all traces of turpentine.Wipe clean several times and then heat up the iron to full temperature( Max: temp ) and iron an old cotton cloth to remove the traces of soap and turpentine ( and also the smell ).
I am trying to repair
I have/had a similar problem. Here's how I fixed it. UNPLUG THE TOASTER 1. Clean the crumbs out throughly. I removed the bottom of the toaster (6 screws) to make sure all the debris was removed. Use a soft brush. Replace bottom and tighten screws. 2. Gently brush the sensor area in the 'one slice' slot with a soft brush. 3. Remove 'darker-lighter' knob. I gently pried mine off with a small screwdriver. 4. Plug toaster in. 5. Put a slice of your usual bread in the 'one slice' slot. 6. Watch it toast. 7. When 'done' to your liking slowly rotate the control counter clockwise using a small screwdriver until the toaster stops toasting. 8. Replace knob with the pointer at the mid point (up and down) to allow for minor adjustments.
My bread falls when baking
Hi visibility...
Couple of things to try...
1... Do not open the oven when baking your bread, only open when done.
2...You can try adding a bit more baking powder to the bread mix.
Please take time to rate me
