20 Most Recent Shark Navigator Lift-Away Bagless Upright Vacuum, NV351 Questions & Answers
I need a wiring diagram for the shark quantum vacuum cleaner
AS far as I am aware and I have been in the trade for many years, there are limited spares for the Shark range and no schematics or diagrams due to their policy. If it fails under warranty, they replace it, they don't attempt to repair them because it is not cost effective.
3/30/2024 8:44:23 AM • Shark Vacuums • Answered on Mar 30, 2024
My Shark Navigator, makes loud noise when switched to carpet. It's not clogged and there isn't any hair wrapped around rollers. How can I troubleshoot this?
They are all called 'Navigator' :>D https://www.google.com/search?q=Shark+Navigator When switch to carpet, the difference is that the brush roller turns. When it is on hard floors setting it doesn't. Remove the base plate, remove the brush and the belt. There is likely something wrapped around the drive spindle or clutch.
How to reduce high pitch noise of Shark vacuums
Digital Trends https://www.digitaltrends.com > Smart Home > Guides Apr 6, 2022 - You can adjust the height on a Shark vac to accommodate certain levels of rugs, carpet, etc. If the vac has been set too high for the current ...
Loud rotating carpet brush noise: Just got my new Shark
Fixya https://www.fixya.com > support > t15932203-loud_r... It seems that your drive belt for the beater brush is stretched. This is a common problem -- if you flip the vacuum over so you are looking at the bottom, you ...
4 Reasons Why Shark Vacuum Is Making Noise
howtofixit.net https://howtofixit.net > shark-vacuum-making-noise Aug 20, 2021 - Another cause behind the loud noises coming from your Shark vacuum is an overly dirty or damaged filter. Remember: air must be able to pass ... ‎Loud Or High Pitch Noise · ‎Blockages · ‎Rattling Noise · ‎Belt Snapped In Powerhead
Does anyone know why my vacuum might be making a ...
Reddit · r/VacuumCleaners 10+ comments · 2 years ago I agree, suction relief valve is popping because of a blockage. Check the extension wand too. The air goes from floor head, lower hose, ... 6 answers · Top answer: That's the suction relief valve. There is a blockage somewhere in the system, either in the ... Loud Air Coming Through Side Vent, Brushroll Not Spinning Dec 4, 2020 How to fix this without taking it in? Shark vacuum - Reddit Sep 27, 2022 Shark making weird suction noise : r/VacuumCleaners - Reddit Aug 13, 2022 Shark Vacuum Making Strange Noise and Not picking up Dirt Sep 22, 2022 More results from www.reddit.com
11/22/2023 8:40:43 PM • Shark Vacuums • Answered on Nov 22, 2023
Where can I get a manual for a Shark Navigater Liftaway Vacuum model CU512 26
It looks like Shark uses one manual for all models in a given series of their vacuums. The manual for the Shark Navigator Lift-Away CU500 series vacuum is available here: https://support.sharkclean.com/hc/en-us/articles/4402173925138-CU500-Series-Shark-Navigator-Lift-Away-Owner-s-Guide . The PDF of the manual is currently here: https://support.sharkclean.com/hc/en-us/article_attachments/4402165819282 . Some Shark device manuals are accessible from the links on the right side of the page. I hope this helps. Cindy Wells
11/10/2023 10:55:06 PM • Shark Vacuums • Answered on Nov 10, 2023
Where exactly is the shark navigator reset button
no reset
11/8/2023 2:53:16 PM • Shark Vacuums • Answered on Nov 08, 2023
Shark Vacuum power brush disassembly?
Screeching would normally be the belt slipping because the brush doesn't spin freely. https://www.google.com/search?q=Shark+Vacuum+power+brush+disassembly Other ideas on screeching. https://www.google.com/search?q=Shark+Vacuum+power+head+screeching ....
9/28/2023 3:57:38 AM • Shark Vacuums • Answered on Sep 28, 2023
Where can I get a replacement check valve for a Shark Steam Mop? I can not find any info about the size or a place to order.
I am also looking for a replacement check valve for the S3501 shark steam mop. Can't find it anywhere online.
9/4/2023 3:51:34 PM • Shark Vacuums • Answered on Sep 04, 2023
2answers
Roller bar on shark cordless vac. not turning, replaced it and still doesn't work. It is clean of debris too.
It is possible that the issue is with the motor or an electrical component. If you have access to a multimeter, you could try testing the motor and other electrical components to see if they are working properly. If not, then it may be necessary to replace the motor or another component. You may also want to make sure that all of the wiring connections are secure and not damaged in any way.
2/23/2023 12:52:55 PM • Shark Vacuums • Answered on Feb 23, 2023
Shark X15Z. I can't find the placement back cover for it
Parts suppliers including the maker https://www.google.com/search?q=Shark+X15Z+parts ..
2/16/2023 7:11:34 AM • Shark Vacuums • Answered on Feb 16, 2023
I need a diagram of the wires in a shark professional vacuum handle
You can find diagrams of the wires in a Shark Professional Vacuum Handle online. You can search for the specific make and model of your vacuum to find the diagram. Alternatively, you can contact the manufacturer of your vacuum to request a diagram.
1/29/2023 10:45:30 AM • Shark Vacuums • Answered on Jan 29, 2023
Do you sell a water reservoir filler cap for the Shark liftaway steam cleaners model S3901
We aren't Shark, we are FIXYA and we don't sell anything. Here you go https://www.google.com/search?q=water+reservoir+filler+cap+for+the+Shark+liftaway+steam+cleaners+model+S3901
Water Tank Cap (1082SO) ' Official Shark® Replacement ...
https://www.sharkclean.com > parts > all > water-tank-cap Description. Replacement water tank cap for the Shark® Professional Steam Pocket® Mop. Works with these models: Shark® Professional Steam Pocket® Mop. US$4.95 ..
1/20/2023 3:09:55 AM • Shark Vacuums • Answered on Jan 20, 2023
Shark Navigator Lift-Away Upright Vacuum. Where exactly is brush bar reset button on shark navigator please?
Question edited for clarity and correct name of the vacuum. Where is the shark vacuum brush bar reset button? You can find the shark brush-bar reset button on the underside of the vacuum. Jul 12, 2020
Is Your Shark Vacuum Brush Not Spinning? This Is Why!
1/20/2023 2:53:47 AM • Shark Vacuums • Answered on Jan 20, 2023
2answers
I have a Shark Navigator Liftaway Delux. It has no suction power and is making a loud hissing noise from the hole on the right side bottom of canister
Shark uses a suction bypass valve on their units. The reason is the vacuum air cools the motor and if there is an obstruction in the line, airflow stops and the valve opens to keep the motor cool. The sound you hear is the bypass being open. You have an obstruction somewhere.
1/2/2023 12:35:40 AM • Shark Vacuums • Answered on Jan 02, 2023
My shark liftaway delux keeps popping releif valve. how do i fix it?
1 or more of the filters are clogged. Try removing them 1 at a time. I'd start with the hepa filter (where the air comes out of the vac)
12/31/2022 6:28:58 PM • Shark Vacuums • Answered on Dec 31, 2022
Cleaned the filters. I checked for clogs - none. My Shark Lift Away still makes a hissing noise and suction is diverted thru a small hole on the side of the housing below where the filters sit inside.
The sound is probably the suction release valve opening up which indicates a clog or restriction somewhere
12/31/2022 6:27:44 PM • Shark Vacuums • Answered on Dec 31, 2022
3answers
My Shark Navigator will not turn off. Works well otherwise.
faulty on/off switch
12/23/2022 7:21:52 PM • Shark Vacuums • Answered on Dec 23, 2022
Shark Navigator Lift-Away Bagless Upright Vacuum, NV351 Logo
4 questions posted
Top Shark Vacuums Experts
vince
Paul Carew
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Shark Vacuums
  • Shark Vacuums
Most Popular Question
empty shark bagless
  • Vacuums
