20 Most Recent Imperial IR-6-G24-C Elite Gas Kitchen Range Questions & Answers
Customer has a propane converted ir-6-g24 that has
try a gas fitters shop for the parts
10/19/2017 5:36:18 AM • Imperial... • Answered on Oct 19, 2017
Imperial electric standard oven IR-6-G36T-E not heating. What could be the reason?
if thermostat is broken try fixing that
6/15/2023 1:02:31 PM • Imperial Kitchen... • Answered on Jun 15, 2023
My 25 year old Imperial 6 burner the oven temperature only gets to 425 I'm in Denver at 5200 ft is what should the oven temp be
We have no means to look that information up for you.
3/29/2018 5:51:38 PM • Imperial Kitchen... • Answered on Mar 29, 2018
Oven gas will not flow with pilot lit
There are basically two types of ranges to deal with:
those with sealed top burners, which are pretty much the standard today, and the conventional, 'non-sealed' ones.
While they operate in much the same way, their conversion is usually different. There are still a few ranges that use adjustable sealed burner orifices, but most are 'fixed' and must be individually replaced to convert each burner from one fuel to another.
(An orifice is simply a small brass fitting with a specifically sized hole very accurately drilled through it, and, if adjustable, has a provision to change the size of this hole by turning closed a threaded portion).
Either way, basically what you're doing when going from natural gas to LP is changing to a smaller orifice to allow for the higher pressure supplied by the 'bottled' gas (The available energy in each ft of gas is different too, but for our purpose here that's not important). Natural gas supplies typically run around a pressure of 5.5 inches water column, while LP runs at twice that pressure, averaging around 11 inches.
The orifice through which the gas travels to the burner must be smaller to accommodate this difference.
Adjustable orifices are simply 'snugged' down, clockwise, with a 1/2 inch open-end wrench, to convert them. Nearly all oven burners use these too - more about that in a minute.
Fixed orifices are replaced, and the good news is: the LP parts are usually included with the new range. On some brands (GE being one), the unused set is attached to a storage point on the stove, and this is a great idea. This way, they can't get lost, and if you ever want to convert back, there they are!
The not-so-good news: these little top burner orifices very often require a metric wrench to remove & install. And some can't be changed without a very slender wrench or nut driver. If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
1/12/2015 2:21:05 PM • Imperial Kitchen... • Answered on Jan 12, 2015
3answers
Where is the pilot light for imperial range oven
Hello. I will try to guide you, in the area that you described, there should be a pilot safety valve, and usually they have a red button you depress in order to get gas to the pilot. The pilot is usually beyond the safety, if you follow the pipe from the safety, into the burner area, that will lead you to the pilot. Put your match,lighter of choice there, while holding in the red button. wait approx. 30 to 60 seconds, then release. If all is well, your pilot is now lit, however you still may need some attention, like cleaning the pilot and orifice. If not, you will need possibly a thermocouple for the pilot/safety, or a safety. Either of those I would suggest you call a local service company, check your phone book under "restaurant equipment repair"
Hope that helps, and thank you.
9/23/2014 3:50:48 PM • Imperial Kitchen... • Answered on Sep 23, 2014
0answers
Imperial IR-6-G24-C Elite Gas Kitchen Range Logo
Popular Tags
2 questions posted
Top Imperial Kitchen Ranges Experts
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
john h
Are you an Imperial Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Imperial Kitchen Ranges
Most Popular Question
customer propane converted ir 6 g24
  • Kitchen Ranges
