20 Most Recent Kenmore HE3 Steam 7.2 cu. ft. Super Capacity Electric Dryer Questions & Answers
2answers
Dryer is set to run 40 mins when it shouts off at 0 on the dryer is has only run 20 mins according to my stove timer
Dryer has a moisture sensor that detects the clothes are dry so it shuts off earlier. If the clothes are still damp then the dryer vent may be plugged and causing the unit to run hot or not able to fully evacuate the air from the machine. Clean the vent and make sure it's completely free and try again. If it short cycles again and clothes still damp you may have a sensor controller issue.
6/18/2014 9:26:58 PM • Kenmore HE3... • Answered on Jun 18, 2014
Kenmore elite he3 washer F02 error during wash cycle
You need to check for a blockage, F02 code indicates -- Drain blocked, kinked, drain filter plugged, or drain pipe exits too far above the washer.
12/31/2012 6:26:39 PM • Kenmore HE3... • Answered on Dec 31, 2012
2answers
Drum spins off center and clothes get stuck between drum and casing
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
4/23/2024 11:52:33 AM • Kenmore Dryers • Answered 19 hours ago
2answers
Trying to find out how much part #7 on the exploded view of the Kenmore elite electric dryer model 110.2808 is? It is a motor.
110.2808 is an incomplete model number. Motors are typically $140 to $180 USD https://www.easyapplianceparts.ca/PartInfo.aspx?inventory=334304&SourceCode=18 This is is a typical Kenmore model designation and is probably the matching washer to your dryer. Yours is missing 4 numbers. Label in the back, label on the door frame, mentioned on the manual.
Model # 11028081700 Official Kenmore Elite washer
https://www.google.com/search?q=Kenmore+elite+electric+dryer+110.2808 ..
2/23/2024 6:44:28 PM • Kenmore Dryers • Answered on Feb 23, 2024
Is it possible to reverse the direction that the door opens on Kenmore Elite Quietpak 4?
Yes, it looks like you can. Don't forget though that you have to get inside and move the door switch. https://www.google.com/search?q=Kenmore+Elite+Quietpak+4+reverse+door ..
1/26/2024 12:16:00 AM • Kenmore Dryers • Answered on Jan 26, 2024
Kenmore ELE-2406028 Laundry Dryer. Help with door switch replacement.
It is an easy enough job. The videos show how. The parts are here https://www.google.com/search?q=Kenmore+ELE-2406028+door+switch ..
1/2/2024 4:11:27 AM • Kenmore Dryers • Answered on Jan 02, 2024
8546206 tech sheet
What is the question? Do I have the tech sheet? Yes I do.
12/17/2023 6:48:07 PM • Kenmore Dryers • Answered on Dec 17, 2023
Looking for age of Kenmore gas dryer Model 110.77741600
The are various idea here.
I have model and serial #s for my washer/dryer. What year ...
iFixit https://www.ifixit.com > Answers > View > I+have+m... Apr 3, 2017 - I have a Kenmore washer and dryer. I have the model #s and serial numbers. I need to know what year ( how old are my appliances?) of the models. 4 answers · Top answer: Erin Morrissey , How to find out the manufacture date of a Kenmore washer or dryer by the ... How old is my dryer? - Kenmore 110 Series ... 2 answers Mar 11, 2022 How old is my kenmore washer/dryer combo? - iFixit 2 answers Aug 4, 2018 help me find out how old this washer is - iFixit 2 answers Sep 29, 2021 What is this dryer model number? - Kenmore Elite ... 2 answers Jul 18, 2016 More results from www.ifixit.com Missing: 110.77741600 ‎' Show results with: 110.77741600
Can you tell me the age of a dryer from the model or serial
JustAnswer https://www.justanswer.com > Appliance Repair May 19, 2023 - Can you tell me the age of a dryer from the model or serial # Kenmore 600. Model is 110 78652700 serial is - Answered by a verified ... 1 answer · Top answer: Good afternoon. My name is ***** ***** I'll be assisting you with your appliance today. Please ... Missing: 110.77741600 ‎' Show results with: 110.77741600
12/15/2023 2:51:24 AM • Kenmore Dryers • Answered on Dec 15, 2023
2answers
Installation manual for kenmore dryer model 110.62872102
Hello, this is Ava with Think Crucial. You may find the User's Manual for your Kenmore model by clicking the link below. 11062872102 KENMORE RESIDENTIAL DRYER Manual Sears PartsDirect You can purchase a wide variety of high quality appliances replacement parts direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/collections/appliances I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
11/28/2023 8:45:45 PM • Kenmore Dryers • Answered on Nov 28, 2023
2answers
Kenmore dryer won't start
https://search.yahoo.com/search?fr=mcafee&type=E210US1494G0&p=kenmore+dryer+will+not+start
11/18/2023 8:25:14 AM • Kenmore Dryers • Answered on Nov 18, 2023
How to change time settings on a Kenmore series 600 electric dryer
Follow these simple steps:
  1. Turn on the dryer by pressing the "Power" or "Start" button.
  2. Use the "Time Dry" or "Timed Dry" button to select the desired drying time. Press it repeatedly to increase the time in one-minute increments or hold it down to scroll through the time options more quickly.
  3. Once you've set the desired drying time, press the "Start" button to begin the drying cycle with the new time settings.
11/8/2023 8:37:58 AM • Kenmore Dryers • Answered on Nov 08, 2023
My Kenmore just stopped while heating something... shows No power... any ideas?
Your Kenmore Dryer has a number of things that can cause this. Most basic, the house breaker has tripped. The timer or electronic mainboard has failed. The element has failed One of the 3 heat regulation devices has failed or tripped out, one resets itself, the thermal fuse has to be replaced. 'make model (what it is)' in all questions please. ..
11/5/2023 12:45:42 AM • Kenmore Dryers • Answered on Nov 05, 2023
2answers
How do i fix a squeaky kenmore dryer model #41784052500
It sounds like a worn bearing but I have found bra wires caught in the holes causing a squeeking sound, either way it has to be dismantled, not a job for an amature.
10/23/2023 6:24:44 PM • Kenmore Dryers • Answered on Oct 23, 2023
Dryer heats on high but not on medium or low
Yes, the contact in the switch are probably dirty or burned.
10/3/2023 4:23:25 PM • Kenmore Dryers • Answered on Oct 03, 2023
Kenmore HE5 dryer sensing/revising estimated time light on, dryer won't start?
Help in the link https://www.google.com/search?q=Kenmore+HE5+dryer+sensing%2Frevising+estimated+time+light+on%2C+dryer+wont+start The previous Answer you may have seen was generated by a Chat GPT4 bot, so was deleted along will all its other answers. ..
9/29/2023 5:00:37 PM • Kenmore Dryers • Answered on Sep 29, 2023
My Kenmore 500 gas dryer heats but won't tumble
limited info generic answer check and test motor -circuit and belt
9/22/2023 12:29:40 PM • Kenmore Dryers • Answered on Sep 22, 2023
I have a kenmore elite model# 110.61066000 will not stay running
check for any loose connections or faulty components
8/20/2023 9:49:14 AM • Kenmore Dryers • Answered on Aug 20, 2023
Kenmore HE3 Steam 7.2 cu. ft. Super Capacity Electric Dryer Logo
2 questions posted
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dryers
  • Kenmore Dryers
Most Popular Question
kenmore elite he3 washer f02 error
  • Dryers
