20 Most Recent Sears Kenmore 24 in. Electric Laundry Center with Dryer - 8875 Questions & Answers
It could be possibly the belt. or if not, possibly a wire grounding out.
Most likely the belt. If the motors on a bind or going bad, it can smell like that also
Sears Dryers | Answered on May 27, 2014
element or stats
Sears Dryers | Answered on Apr 03, 2014
The heating element is burned out and needs to be replaced
replace timer
Sears Dryers | Answered on Nov 11, 2012
ASK YOUR LOCAL DEALER WE DO NOT KNOW THE MAKE OF IT duh
Dryers | Answered on Dec 11, 2019
WHAT KIND OF MATERIAL IS THE PIPE . SHOULD BE METAL IF PLASTIC YOU MIGHT HAVE RAT PROBLEM
Dryers | Answered on Dec 09, 2019
  • Incorrect branch circuit wiring
  • Incorrect dryer-to-receptacle wiring
Dryers | Answered on Dec 06, 2019
Remove the shade and the tube. Underneath you will see the fixing screws. Behind that is the electrical connections
Dryers | Answered on Dec 04, 2019
Contact the manufacturer/distributor to inquire.
Dryers | Answered on Dec 02, 2019
The belt system and the drum bearings should be replaced
Dryers | Answered on Nov 27, 2019
yes no problem.
For every dryer that has ever been made!!
Google
make model replace element
Look at the video tab
Dryers | Answered on Nov 26, 2019
you do not drycleaN LEATHER you use leather cleaner and conditioners
Dryers | Answered on Nov 25, 2019
In the engine compartment. Next to the battery.
The first thing to check is to be sure the outlet is not on an outlet with a GFCI or AFCI. Those are protection devices that are used in unfinished areas or wet areas like bathrooms and kitchens. Electrcians can wire outlets some distance away from the actual device (AFCI or GFCI) and when it trips you cannot tell without looking for it. To tell if that is the case in an outlet, there are two buttons on the outlet with R and T on them. R means reset and T means test. Press the R on the outlet to reset it. If that does not change the situation, look in the breaker box for those ACFI and GFCI devices to be incorporated into a breaker and be sure that they are not tripped. IF that is not the case and no ACFI or GFCI is present, then you need to locate the circuit breaker for the outlet that you are working on AND SHUT IT OFF. Once this is done you can remove the cover plate on the outlet and then the screws holding the outlet. Pull the outlet from the box and check the wires. IF the wires appear ok, you need to see where that outlet connects to. THis connection can be to another outlet in the same room of it may connect to the box and the ceiling where the light is located. You need to check for all the connections in the celing box and look at the wire nut that the electricians use to be sure the connections are good. In some cases the connections can come loose and the outlet fails.
Dryers | Answered on Nov 22, 2019
YOU DON'T SINCE YOU COOKED IT IN/ON THE METAL
Dryers | Answered on Nov 21, 2019
Request the diagram from Defy.
Sears Kenmore 24 in. Electric Laundry Center with Dryer - 8875 Logo
1 questions posted
Top Sears Dryers Experts
Andrew Taylor
Andrew Taylor
James Steuber
James Steuber
Level 1 Expert
Are you a Sears Dryer Expert? Answer questions, earn points and help others
View Most Popular
Sears Dryers
  • Sears Dryers
Most Popular Question
sears electric dryer flashing f01 wrong
  • Dryers
