20 Most Recent Sears Galaxy 30" 1.5 cu. ft. Microhood Combination Microwave Oven 8002 Questions & Answers
Sorry to write this but it is likely a failed main board and the replacement may not even be available or too expensive to bother with.
Sears Galaxy 30"... | Answered on Jan 09, 2015
Hi superchar416...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or inside of the dryer venting system,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if you do not read continuity you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
Try to run the dryer, if it runs and heats up then replace the thermal fuse/thermistor/thermostat.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,then you do not have to tape the wires together as described above.
But do not trust the ohm meter all the time, because sometimes it will give a false positive that the fuse is ok when in reality it is faulty.
DO THE FOLLOWING TEST:
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check the fuse/thermostat,thermistor for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
This test of the thermal fuses,thermistor,thermostat, will show if the thermal fuse,thermostat,thermister is really faulty or not.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc. If you have to replace your blower wheel it will remove clockwise as looking at the blower wheel. You will have to hold the belt end of the motor with a vise grip pliers or maybe the shaft of the motor has a notch cut on it for a wrench to fit.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
If you do not have a volt/ohm meter then:
DO THE FOLLOWING: Remove the wires and tape them together and try to start the dryer.If the dryer starts then replace the fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Sears Galaxy 30"... | Answered on Sep 20, 2012
It could be possibly the belt. or if not, possibly a wire grounding out.
Most likely the belt. If the motors on a bind or going bad, it can smell like that also
Sears Dryers | Answered on May 27, 2014
element or stats
Sears Dryers | Answered on Apr 03, 2014
The heating element is burned out and needs to be replaced
replace timer
Sears Dryers | Answered on Nov 11, 2012
PERHAPS IF WE KNEW WHAT THE DEVIL IT IS BUT ALAS YOU DIDN'T MENTION THAT ,DID YOU?
Dryers | Answered 13 hours ago
I would say you have a serious short in the wiring.i wouldn't use till I took it apart and looked at it you will see the burnt wires I would say be safe
Dryers | Answered Yesterday
WITHOUT TESTING HOW WOULD WE GUESS CALL LOCAL REPAIR SERVICE
Dryers | Answered 2 days ago
HOW WOULD ANY ONE GUESS WHAT YOU HAVE ASK THE MFG ONCE
Dryers | Answered on Jan 16, 2020
Possibly Cissell - if that is the same brand name instead of Cassell. Same question asked many times without answers according to search using https://www.google.com
Possible manual at the link below, but hard to known without model number:
https://www.manualslib.com/brand/cissell/dryer.html
belt or drum roller issues
THERE IS NO RESET
Dryers | Answered on Jan 14, 2020
Either your switch, relay, Resistor or blower motor is bad. You can test them all.
Dryers | Answered on Jan 13, 2020
then call your local repair shop if you can not figure out how to get to it
Dryers | Answered on Jan 10, 2020
Sears Galaxy 30" 1.5 cu. ft. Microhood Combination Microwave Oven 8002 Logo
3 questions posted
Top Sears Dryers Experts
Andrew Taylor
Andrew Taylor
James Steuber
James Steuber
Level 1 Expert
Are you a Sears Dryer Expert? Answer questions, earn points and help others
View Most Popular
Sears Dryers
  • Sears Dryers
Most Popular Question
fan runs all time rest microwave works
  • Dryers
