20 Most Recent
Sears Kenmore Elite Gas Dryer Front Load Steam 8.0 Cu. Ft Questions & Answers
Kenmore Washer smell like burning rubber
It could be possibly the belt. or if not, possibly a wire grounding out.
Most likely the belt. If the motors on a bind or going bad, it can smell like that also
5/27/2014 6:03:45 PM •
Sears Dryers
Answered
on May 27, 2014
Remote not working at install Casa Turbina DC 60
Do you have a phone with a front facing selfie camera? Face the front of the remote at the camera and press a button. You should see a flash. If you don't, the batteries need changing or the remote has failed.
4/21/2024 12:53:31 AM •
Dryers
Answered
2 days ago
Holmes HSF1610A 16" floor-standing fan. Replacement part for my fan?
No replacement parts generally, and all are obsolete. Holmes themselves send people to eReplacement parts, and they say obsolete. Fix with Epoxy adhesive or putty, or have the part 3D printed or buy new one.
e Replacement Parts
Holmes Products
https://www.holmesproducts.com > e-replacement-parts
Replacement Parts. The link below will take you to a site outside of Holmes. ... Call 1-888-472-5853 for Holmes Bedding. Call 1-800-546-5637 for Holmes Appliances.
Holmes Fan Replacement Parts by Model
eReplacement Parts
https://www.ereplacementparts.com > holmes-fan-parts-...
Shop OEM Holmes Fan parts that fit, straight from the manufacturer. We offer model diagrams, accessories, expert repair help, and fast shipping.
Holmes Replacement Parts ' Fast Shipping at Repair Clinic
Repair Clinic
https://www.repairclinic.com > Shop-For-Parts > Holme...
Find Holmes Replacement Parts at RepairClinic.com. Repair for less! Fast, same day shipping. 365 day right part guaranteed return policy.
Holmes - Heating & Cooling Parts & Accessories ...
Amazon.com
https://www.amazon.com > Heating-Cooling-Parts-Acce...
Online shopping for Home & Kitchen from a great selection of Stove & Fireplace Accessories, Air Conditioner Parts & Accessories, Air Purifier Parts
4/20/2024 12:29:02 AM •
Dryers
Answered
3 days ago
How can I find my necklace in my dryer?
First check the lent catching screen and then the vent and hose and the ground below the vent exit. Completely clean those out. If you don't find the necklace in that process, turn the dryer on to see if it will eject the necklace into the vent hose. If it is trapped behind the drum, you should be able to hear it rattling around. However, dismantling the dryer can be dangerous so you should consider a hiring a dryer repairman to do that if it is necessary.
4/7/2024 3:27:06 AM •
Dryers
Answered
on Apr 07, 2024
Faqe7077kw0 dryer beeps 3 times won't start replaced the door switch same problem. Hold in the select button and press start and it will run until I let up on the select button
- Check the Power Supply:
- Ensure that your dryer is receiving proper power. Use a multimeter to test the wall plug. You should have two poles giving 110-120 volts each and a ground. If only one side is hot and the other is not, you could have issues.
- Common Causes for Dryer Not Starting:
- Let's explore some common reasons why your dryer might not start:
- Thermal Fuse: The thermal fuse is a safety device that protects the dryer from overheating. If it's blown, the dryer won't start. Test it for continuity using a multimeter Check your exhaust vent for restrictions..
- Start Switch: If the dryer hums but doesn't start, the start switch might be faulty. Test it for continuity with a multimeter.
- Door Switch: The door switch activates when the dryer door is closed. Listen for a "click" when you start the dryer. If you don't hear it, test the door switch for continuity.
- Door Switch Solution:
- If the door switch isn't "clicking," it might be the culprit. Try this:
- Push the length of the switch from side to side (without removing it) to see if it clicks.
- If it clicks, it's likely not defective.
- Reassemble the dryer to see if it works.
Remember to
safely disconnect the power before attempting any repairs. If these steps don't resolve the issue, consider seeking professional assistance or further diagnostics
3/13/2024 3:16:44 AM •
Dryers
Answered
on Mar 13, 2024
