20 Most Recent
Miele T8000 Series : T8005 24 Electric Dryer Questions & Answers
My miele rotary iron B995D keeps tripping the eletrics when it heats up
One of the most common reasons is a faulty heating element. Over time, the heating element can malfunction and become unresponsive, causing the thermal safety mechanism to trip your circuit breaker as a safety measure. If this is the case, you might even hear beeping coming from the iron. The only solution here is to replace the element or replace the iron altogether, depending on the make and model of the iron.
Another possible reason is an overloaded circuit. If you have too many electrical appliances plugged into one circuit, it can cause your circuit breaker to trip. Try unplugging some items from the circuit and see if that helps.
If after this, you continue to have problems, an appliance repair technician is the alternative for a possible repair.
10/28/2023 4:41:07 PM •
Miele Dryers
Answered
on Oct 28, 2023
Condenser dryer pump not working when dryer is hot
It sounds like your Miele T 494C Condenser Dryer may be experiencing an issue with the pump not functioning properly during hot cycles. It is likely that the pump is overheating and causing it to malfunction.
One possible cause of this issue could be a clogged pump filter. Over time, lint and other debris can build up in the pump filter, reducing its efficiency and causing it to overheat. Cleaning or replacing the pump filter may resolve this issue.
Another possible cause could be a malfunctioning thermostat that is not controlling the temperature correctly and causing the pump to overheat.
If the pump is overheating, it could be caused by a malfunctioning thermostat, which would need to be replaced by a professional technician.
It's also possible that the pump may be damaged or worn and needs to be replaced.
It's recommended to consult the manufacturer's manual or contact the manufacturer's customer service for further assistance. They may be able to provide more specific troubleshooting steps or recommend a professional technician to repair the dryer. Keep in mind that attempting to repair a dryer can be dangerous if you're not familiar with the proper procedures and safety precautions.
Regenerate response
1/17/2023 11:41:40 PM •
Miele Dryers
Answered
on Jan 17, 2023
Miele professional dryer blows air into drum even after cycle ends
Everything should be off before the program starts and should stop at the end of the cycle. For oddities like that, you need Miele Service. They are all computer diagnosed on the engineer's laptop computer. Sounds like a control board issue, but hopefully can be reprogrammed.
7/3/2022 4:06:34 PM •
Miele Dryers
Answered
on Jul 03, 2022
Miele t9800 dryer running hot in normal setting
There is a small component above the heating coil. It is your temp regulator. It is a small round component wired in line with everything. should only be two wires and easy to fix/replace yourself. You will need to get the part number off it or have the make and model when you go to get a replacement part for it.
1/12/2022 2:27:49 AM •
Miele Dryers
Answered
on Jan 12, 2022
