20 Most Recent LG LW1012ER 10,000 BTU Medium Window Air Conditioner w/ 450 Square Foot Capacity, 3 Pints Per Hour Dehumidifier, 3 Fan Speeds, 24 Hour Timer, 300 CFM, GoFin Anti-Corrosion Coating, Thermistor Thermostat, 4-Way Air Deflection, WashabPermanent Filter, Ins Questions & Answers
Why does it beep when plugged in?
as there are two control boards in ac units ( split systems) and one in a window unit it could be the inside board ( they do not suffer power surges to well or vermin infestations at all ) before you waste more money I suggest that you get a technician in to determine the fault and if parts are readily available.
6/24/2015 2:51:43 AM • LG LW1012ER... • Answered on Jun 24, 2015
2answers
LG Dehumidifier model LHD459ELY9. No power to the display?
Question edited, toss in a load of CAPS. The capacitor is likely to have failed internally. It can still produce voltage. Or the transformer that supplies power has failed. No one else has recorded this issue https://www.google.com/search?q=LG+Dehumidifier+model+LHD459ELY9.+No+power+to+the+display ..
2/26/2024 6:37:19 PM • LG Dehumidifiers • Answered on Feb 26, 2024
I picked up an LG LDF7551ST dishwasher used, there is a white plastic thing on the left side, assuming water inlet mechanism?
https://www.searspartsdirect.com/manual/44av6atl6i-003204/lg-ldf7551st-dishwasher-parts?sid=sem:ggl:dsagroupb:141452280898::c&keyword=&gclid=Cj0KCQiAtICdBhCLARIsALUBFcHCsKc_OEAYHAPPbyS-9LcLCYIAojCvzFzeIbtp7dOcMwOBVditVK8aAhxCEALw_wcB
12/19/2022 4:08:55 PM • LG Dehumidifiers • Answered on Dec 19, 2022
My LG model UD701KOG3 Dehumidifier does not shut off when the desired set level is reached.
The bucket is drained continuously with hose connected - no need for "full" sensing
7/28/2021 8:15:16 AM • LG Dehumidifiers • Answered on Jul 28, 2021
What does the code 24 and CH mean on my LG dehumidifier?
Hello everyone, can someone please tell me what is error code CH10 on lg dehumidifier please?
Thank you
7/25/2019 6:44:04 PM • LG Dehumidifiers • Answered on Jul 25, 2019
2answers
LG LD450EAL no power
Try resetting the GFI breaker, assuming it is connected to one. Also check the main breaker panel to make sure the breaker is not tripped. Unfortunately the electronic panels do go bad in these systems after a few years of service. Try resetting the unit. There should be a tiny reset button on the back. Also if the bucket is full it will not turn on, make sure it is in place and seated properly or it will not turn on. There may be a reset on the cord itself as well, hope this helps.
11/28/2018 8:32:28 PM • LG Dehumidifiers • Answered on Nov 28, 2018
How do you clean the air filter?
Here's a link to an article written by a service technician with more than 30 years of experience. It gives details on How to Clean Dehumidifier
9/4/2017 11:43:39 AM • LG Dehumidifiers • Answered on Sep 04, 2017
LG LW1012ER 10,000 BTU Medium Window Air Conditioner w/ 450 Square Foot Capacity, 3 Pints Per Hour Dehumidifier, 3 Fan Speeds, 24 Hour Timer, 300 CFM, GoFin Anti-Corrosion Coating, Thermistor Thermostat, 4-Way Air Deflection, WashabPermanent Filter, Ins Logo
1 questions posted
Top LG Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
View Most Popular
LG Dehumidifiers
  • LG Dehumidifiers
Most Popular Question
air conditioner beeps when plugged in
  • Dehumidifiers
