20 Most Recent
Rascal 600 T Electric Scooter w Seat Lift - Used Mobility Scooters Questions & Answers
Mobility Scooters
If your scooter has power and the horn works, If when you sit on the scooter you can push with your feet backwards on the scooter. Then you have to check your freewheel lever because it is unlocked and won't drive.
Onboard battery charger quit working.
hi William, there is a fuse located until the rear cover please check that's okay , if so then sadly the charger unit has failed, i can supply you with a normal charger lead that you fit to the batteries and will allow you to use a normal three pin charger, a lot cheaper than a replacement unit ..
Regards
Rob
Wiring schematic rascal 600 24v electric
hi, firstly what controller is fitted (curtis) ? then i can give you a ideal controller wiring schematic but you won't get hold of a Rascal one..
Regards
Rob
www.gewizrepairs.co.uk
My charger on Rascal 600 does not charge. After
Most chargers are 3 pin. Plus and minus charging voltage to the
batteries and a third pin monitors the actual battery voltage, so
that the automatic charger can turn itself off once the batteries
are fully charged. As Brad has mentioned, the connection
from the charger has to be made for the charger to produce
a voltage at those pins. The best way to see if it is charging
is to remove the seat and measure across both batteries..
assuming it's a 24volt system like most. Charging voltage
can be as high as 28volts across the positive of one 12volt
battery (connected in series to the other 12v battery) and the
negative of the other battery. You can monitor the charging
voltage across the batteries with a digital volt meter.
Can you remove the reverse beep
Best way is to locate the beeper. There should be two wires coming from it. You can clip the wire and insulate the cut end. Best to cut the red wire if one is there, as it will be the power lead. If you sell the unit later, you can restore the beeper.
Need owners manual
Go to the Electric mobility website and down load a manual or go to your dealer who will obtain it for you.
Starter switch
I would contact your Rascal dealer for a replacement key switch.
You could try spraying some switch cleaner in the key slot and work the key to see if it is just dirt but I would imagine it is worn out.
My scooter will not fully charge
This could be the charger socket is worn and not making a good connection when charging or it could be the charger itself at fault. Now you have changed the batteries, I presume new and both the same type, you need to look at the charging side.
Replacement of rascal 600t headlamp
Hi, To get to the head light bulb you need to take the tiller head apart by removing the screws that go up from the bottom. The top will lift off but be careful not to pull any wires off. This will give you access to the lamp at the front. Make sure you replace the bulb with the same type and voltage.
How do I replace the headlamp bulb?
Hi, to get to the head light bulb you need to take the tiller head apart by removing the screws that go up from the bottom. The top will lift off but be careful not to pull any wires off. This will give you access to the lamp at the front. make sure you replace the bulb with the same type and voltage.
What to troubleshoot for in disconnected wire/s causing power shut down after a bump?
I would check the multi pin socket in the tiller is pushed in all the way. Check the underside of the scooter and track the cable to see if it is damaged anywhere. Where the cable comes up under the seat between batteries, check the plug on the end of the cable.
Also on the seat lift. Check micro switches as I believe the scooter will not run with the seat in the raised position. so check down switch first.
