20 Most Recent
DBX 1215V Home Equalizer Questions & Answers
Mixer and an EQ & amp ?
The order is mixer, equalizer and amp. The output of the mixer connects to the input of the equalizer and the output of the equalizer connects to the input of the amp. The equalizer has three types of input and output connections. They are XLR, 1/4 inch and screw terminals. The mixer will have one or two of the three. Choose XLR if possible on the mixer, choose line level output on the mixer if possible. A XLR male to female cable is needed for the connection. The equalizer has two channels, if the mixer has two output channels the two output channels of the mixer can connect directly to the two input channels of the equalizer. If the amp has two input channels, the two output channels of the equalizer can connect directly to the two input channels of the amp. If the mixer only has one output channel then only one channel of the equalizer can be used and one channel of the amp likewise. A XLR male to female connection cable can be used to connect the equalizer to the amp.
Washer water stays running
There is a solenoid that controls the hot and cold water. If you turn off the washer and the water stops, there may be an issue with one of them. If it continues to flow you may have one stuck open.
1/22/2015 11:03:31 PM •
DBX Audio...
Answered
on Jan 22, 2015
