20 Most Recent
Nike Mettle Sledge Watch WC0040 096 Questions & Answers
One of the screws that connects the band to the
It is unlikely that any hardware store will have the size of screw that you need, since watch screws tend to be much smaller than are generally available.
The best place to go is a watch shop. They should be able to get it replaced for you.
Nike watch problem
Okay, mine's a Chisel but I'm pretty sure the module is similar, if not the same, across the Mettle range.
Anyway, press and hold the light button - marked adjust - until the display says "hold to adjust"; after a couple of seconds the time display will return and the hours will be flashing.
To adjust up, press "start/+" and down press "stop/-". To cycle through the options, press "mode".
Once you're done, press the "adjust" button again to return to regular timekeeping mode.
Enjoy your Sledge - if you don't I'll have it!!
Regards,
Martin.
