20 Most Recent Breitling Aerospace 455 Wrist Watch Questions & Answers
The digital display on my
Open the watch and see if you can find the all reset shunt. It may be a contact requiring to be shunted with with a jeweler's screwdriver or a contact you press on. The all reset much be done with the battery operating. This is a warm boot in this type of case. I have seen this in other models of watches. I do not know your watch, but most of the time the technology is about the same for procedures. If you cannot get it working, simply send it to the manufacture support for service. It could be a processor fault. I have also seen this type of thing.
2/11/2018 8:12:08 PM • Breitling... • Answered on Feb 11, 2018
2answers
Backlight for my breitling aerospace has stopped working, otherwise watch is working perfectly.
I am in South Korea. My back light has stopped working and I took it to the dealer/service office in Seoul and asked them if they could repair it. Then took it apart and said everything works find, but for the back light, I should just order a whole new analog works...is he just trying to make some money off me?
5/18/2017 8:36:09 AM • Breitling... • Answered on May 18, 2017
How to set time on breitling aerospace
http://www.breitling.com/en/service/user-manuals/ press button till in time mode then pull out crown wheel and rotate slowly to adjust minutes or spin quickly to adjust an hour at a time. If the digital and hands don't agree the process for correcting this is in the manual on the link above.
11/10/2014 3:02:09 PM • Breitling... • Answered on Nov 10, 2014
Aerospace changes the date at noon.
wind back 12 hours
7/29/2012 11:39:35 AM • Breitling... • Answered on Jul 29, 2012
Digital display problem. Top display window not
Not good news.The parts are only available from Breitling and this will require the watch is sent to them.There is probably a fault on the circuit,if its out of any guarantee this will be costly.There is a UK Breitling repair centre try Breitling.com or find a good stockist.
Regards
8/19/2010 3:15:17 PM • Breitling... • Answered on Aug 19, 2010
Stopped working and all digital figures displayed!
If the display is not dim the battery is probably OK. Try removing the battery, test it anyway, and after a minute or two replace it (I'd use a new one anyway) and see if the problem is cleared. Sometimes just power cycling will "reboot" the watch. If that doesn't do it I'm afraid it will need to visit a Breitling service center.
4/18/2010 12:02:37 AM • Breitling... • Answered on Apr 18, 2010
Alarm and timer etc... does not sound. the watch
It is likely that the battery is dead.
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yourself.
3/1/2010 4:20:50 PM • Breitling... • Answered on Mar 01, 2010
It's very difficult to adjust my breitling
Normally this is from the crown and case tube being dirty. This slows down the rate at which the crown can be turned so the switch inside cannot get triggered to move the hands quicker. Sometimes the turning action can also be so that the switches do not actually 'see' the crown was turned and so the hands do not move.
The solution is to have your watch serviced.
Hope this helps.
Ken Kotoski
Yellowstone Watch Inc.
www.yellowstonewatch.com
2/19/2010 6:20:58 PM • Breitling... • Answered on Feb 19, 2010
I've got an older breitling aerospace
I have seen other makes which have described how to do this but you do need the manufacturers instructions. These are frequently obtainable from their web site but in this case I couldn't find any.
However, if you go to their web site (www.breitling.com/zh/index.php#/home/), you will see on the left side of the screen a heading "maintenance centers", click on this and choose the one nearest you.
If you contact them they may be able to talk you through the procedure or send you a set of instructions.
2/6/2010 12:02:35 PM • Breitling... • Answered on Feb 06, 2010
B-1 brietling
Well if the watch is performing its functions properly then there's nothing wrong with it technically. The only way one could make it require less turns would be to custom make the necessary parts with different ratios and unless you have got lots of money to spend on that .......
7/27/2009 9:06:26 AM • Breitling... • Answered on Jul 27, 2009
How do I set date & time?
usually breitlings have a screw-in crown with a gasket for diving. If you cannot pull the crown away from the case, try unscrewing it. After a little pressure to the left, the crown should begin to turn. Unscrew it carefully and you should be able to pull it out one stop for the date and all the way (note second hand stops) to set the time. Be careful pushing it back in and screwing it back down. You don't want to potentially damage the threads. The crown is back in place when you ca't screw it in any more and the "B" is straight up and down
7/6/2009 6:52:12 PM • Breitling... • Answered on Jul 06, 2009
Breitling watch move fast
No matter what is your watch movement (quartz or mechanical) it can be adjusted to keep time properly.
Bring it to your nearest watchmaker and the problem will be solved.
9 sec a day is far too much for Breitling.
4/21/2009 8:54:59 AM • Breitling... • Answered on Apr 21, 2009
How do I set this watch
There is an on-line manual for the Breitling Aerospace at http://vbr.com/doku/breitling4.htm
2/19/2009 3:51:51 AM • Breitling... • Answered on Feb 19, 2009
Breightling Air Wolf
Try the on-line manual at http://vbr.com/doku/breitling4.htm
2/19/2009 3:36:59 AM • Breitling... • Answered on Feb 19, 2009
Breitling aerospace stap
If it is the spring that connects the watch to the lugs, It is called a spring bar. You can easily get some on ebay . Or just got o a local independent watchmakrer shouldnt charge you more than $10 to put a new set of spring bars on.
1/6/2009 5:27:15 PM • Breitling... • Answered on Jan 06, 2009
Breitling Aerospace -setting T2
Here is a link for all settings:
vbr.com/docu/breitling4.htm
12/18/2008 5:02:21 AM • Breitling... • Answered on Dec 18, 2008
Breitling b-1 both upper and lower displays are flashing
Reset your watch. If it doesn't work, replace battery.
Here is the link for all instructions:
12/18/2008 4:59:55 AM • Breitling... • Answered on Dec 18, 2008
2answers
Is my breitling bentley j44362 real or fake
fixya doesnt do appraisals-authentic -sell -buy -product products briong to a watch smith
6/22/2023 12:52:59 AM • Breitling... • Answered on Jun 22, 2023
Rolex watch serial no f714983 is this real or not
It is Real. F714983
9/28/2022 10:05:15 AM • Breitling... • Answered on Sep 28, 2022
Breitling Aerospace 455 Wrist Watch Logo
28 questions posted
Top Breitling Watches Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Breitling Watch Expert? Answer questions, earn points and help others
View Most Popular
Breitling Watches
  • Breitling Watches
Most Popular Question
s very difficult adjust breitling
  • Watches
