20 Most Recent
Felker FRS-38 Tile, Marble & Granite Rail Saw Questions & Answers
Why does tile veer off?
If you have a bridge saw. The blade and motor may not be parallel with the rails the motor travels on.
Water pump not working correctly
Probably need a new pump or water tube is clogged. You can try to blow out the pump and water tube with air to clean it internally. You can buy a new pump on line at Contractors Direct for about $50.
3/31/2015 5:44:29 PM •
Felker Saws
Answered
on Mar 31, 2015
Why my Makita disc cutter has spark wont start
If the fuel in it is 2 or more months old dump it out and put in fresh fuel and try statring. Also try try a squirt of starting fluid into the carb. If it fires on it you may need to do this a few times to pull the old fuel in the lines through till the fresh fuel can get to the carb.
4/10/2024 4:13:02 PM •
Saws
Answered
on Apr 10, 2024
