20 Most Recent
JBL PB10 Subwoofer Questions & Answers
My jbl pb 10 has a noise and it burn the fuse...
It blows the fuse because a semiconductor device has developed a short (in otherwords acting like it was just a piece of wire). Because of the noise I would suspect the main amp device is the cause. It will be most likely on a heatsink.
5/25/2021 1:50:02 AM •
JBL PB10...
Answered
on May 25, 2021
My JBL PB10 lights up
As long as its not blowing the fuse it can be saved - look for Edwards Electronics - Ebay - We fix them . Thanks.
5/25/2021 1:47:26 AM •
JBL PB10...
Answered
on May 25, 2021
Jbl sub makes ear splitting noise when plugged into any ac outlet
I have the same problem with my Creative Labs Sub-woofer, which I plan to strip and inspect, as I do electronics.
I've read elsewhere that a faulty capacitor can cause this motor-boating screech.
If your sub can be opened, unplug and look for bulging caps.
The silver top should be flat.
Rounded top usually indicates a blown cap.
Meanwhile, I bought another surround setup, by Logitech.
1/31/2018 11:59:10 PM •
JBL PB10...
Answered
on Jan 31, 2018
Hi, I bought a new JBL SCS 140 system with amp HK
Fuses blow when something is shorted. In this case it will be a semi-conductor of some kind. If the device uses IC for the main amplification then you are right to be worried!
The 158 amp is totally unsuitable for the JBL.
This is the specification of the JBL:
- Recommended Amplifier Power
10 Watt
- they are also 4 Ohm speakers.
- 158 is: Output Impedance / Channel
8 Ohm.
6/2/2017 1:39:26 AM •
JBL PB10...
Answered
on Jun 02, 2017
Blinking signal, sound
Hi my name is MIchael and I repair the following amps JBL PB10, PB12 If it has the screw near the on/off switch. If your amp is blowing the fuse, has bad sound, no sound, doesn't power up or if the output is low or muffled. We can fix it - please check ebay and search WE REPAIR PB10 PB12 - you will find us ... Edwards Electronics ....
5/24/2012 2:48:01 AM •
JBL PB10...
Answered
on May 24, 2012
