20 Most Recent Thermos Grill2Go Fire+Ice Questions & Answers
My Grill will no longer lift
I just had mine apart today because the cable broke. There is only one damper, in the left side where the pedal is. The other side is controlled by a cable that is strung on rollers. My cble broke so i had to replace it with one from a hardware store. I noticed that everything needs to be oiled for the system to work good. The gas strut/damper is inside of the lift tube. I would think it could be matched up with one from an automotive store. Autozone has a pretty good selection of them. But, The strut that is in the grill has a special end on it to fit the lift tube, you would have to somehow fabricate a new end or try to cut and weld or braze the old one onto the new strut. I have not had the strut problem yet because when I store the grill I leave it in the up position. this takes the stress and pressure off of the strut. Hope this helps.
5/23/2022 6:40:50 PM • Thermos Grill2Go... • Answered on May 23, 2022
4answers
Pedal does not bring up grill
If you can still raise it manually, it probably needs new hydraulic struts. Mine actually never worked from new, and I am taking mine apart today to fix it. I will let you know what the part number is of the strut.
6/22/2017 6:40:48 PM • Thermos Grill2Go... • Answered on Jun 22, 2017
The grill doesn't want to Pop-Up. took it apart and sprayed WD40 on it, Cable and Springs are good, still doesn't come up. Any Ideas anyone ? Thanks. **Found out it is a Gas strut/Ram, no Spring.
probably need to replace the gas struts as they do leak gas and are not responsive if you cannot get new struts ,there are places that can re-gas struts
8/5/2015 4:40:26 AM • Thermos Grill2Go... • Answered on Aug 05, 2015
2answers
We need a new regulator and hose for our Thermos
New regulator can be found at amazon, take a look: Amazon com thermos grill2go regulator. have a nice day
12/27/2014 5:27:28 PM • Thermos Grill2Go... • Answered on Dec 27, 2014
I need a gas regulator for my Thermos fire and ice grill
Sure, take a look on amazon for it: Amazon com thermos fire and ice grill. I hope this was helpful. Cheers
12/6/2014 3:27:18 AM • Thermos Grill2Go... • Answered on Dec 06, 2014
Need a regulator for Thermos Grill 2 Go
I bought this to replace the regulator I lost for my Thermos Grill2Go. Little modification to the grill and it worked like a champ. Portable Propane Table Top Regulator 1 by 20 Female Throwaway Cylinder... need-regulator-thermos-grill-2-go-2i4ggwcr0e0sverpwaph0wvr-1-0.jpg
11/25/2014 12:54:00 AM • Thermos Grill2Go... • Answered on Nov 25, 2014
2answers
I need to change head gasket the car over heated. I need TDC mark
You can remove #1 spark plug and let someone bump it over with your finger in the plug hole,when you feel it blow your finger out the hole it's close,stick a screwdriver in the plug hole and turn the belts or crank pulley until the screwdriver is at its highest point .thats true top dead center on compression stroke. Hope this helps and good luck Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/freddy_7b7b71fa225aabf9
10/4/2014 1:22:10 PM • Thermos Grill2Go... • Answered on Oct 04, 2014
One side of the grill base will not rise up
One one side, there is a gas strut which is connected to the other side via a cable, similar to that which you would find on a bicycle for the brake. When the strut side raises (it uses this cable and a series of pulley's) it shortens the cable and raises the other side. With use, this cable where's and can slide off the pulley. It could also be that this cable has been damaged, although the prior is more likely the case. It's fairly easy to disassemble and inspect. One regular and one small philips screw driver, along with a pair of needle nose plier are all the tools necessary. If you would like further info. please let me know.
5/2/2014 12:55:30 PM • Thermos Grill2Go... • Answered on May 02, 2014
What was cost brand new?
I paid it new in 2005 400 AUS in Melbourne. I think value is now 100 AUS (depends from the conditions.I need the grate (mine is broken and I can't use it anymore): If you sell to me all at 50 Euros + Expenses, I can buy it. I cannot find parts anywere....
11/23/2013 11:12:36 PM • Thermos Grill2Go... • Answered on Nov 23, 2013
Grate grill
yes, it is but the manufacturer does not make this available. we have to use other grates that just happen to be the right size and install using the same kind of support.
11/7/2013 11:27:25 PM • Thermos Grill2Go... • Answered on Nov 07, 2013
Thermos Grill2Go Fire+Ice Problem
check it out but get in line behind me:
http://www.charbroil.com/Consumer/product_detail_e.aspx?ProductID=968&CategoryID=
This thing is hard to find. Mine's clogged and it's NFL season baby!!! Not in stock until mid-October but genuine and 22 bucks+shipping!
Happy Tailgating!
10/30/2013 8:22:57 PM • Thermos Grill2Go... • Answered on Oct 30, 2013
0answers
0answers
46563003
Be the first to answer 7/12/2013 4:30:13 AM • Thermos Grill2Go... • Posted on Jul 12, 2013Be the first to answer
Thermos Grill2Go Fire+Ice Logo
120 questions posted
Top Thermos Grilling Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
View Most Popular
Thermos Grilling
  • Thermos Grilling
Most Popular Question
grill doesnt want pop up took apart
  • Grilling
