20 Most Recent
Coby DP-772 Digital Picture Frame Questions & Answers
Coby dp772
You hold down the ENTER button to enable slideshow mode....assuming you may possibly still be wondering after 6 years. :)
I have my sisters
You cant, it requires a SD card be inserted. The frame itself has no internal storage.
Cannot down load pictures to frame from computer
The following instructions should be able to help you transfer pictures/images and music from your computer to the frame.
Power ON the frame.
Connect the small end of the USB cable to the USB port on the side panel of the Digital Photo Frame.
Connect the larger end of the USB cable to the USB port on your computer.
You will see some extra "Removable Disc" drives in "My Computer" -- One
for each of the memory card slots on the Digital Photo Frame. And the
last one is for the Internal Memory of the frame. Double-click on the
last "Removable Disc" icon to access the internal memory of the frame.
From here you can copy images and music files to the frame. You need to
transfer the images or music files into this folder (which is the
internal memory of the frame). Copy the files from your computer and
paste them in this folder.
The picture files should be in the "standard JPEG" format and the music files should be in the "mp3" format.
To disconnect the Digital Photo Frame from your computer:
In Windows, on the bottom taskbar, right click the icon which appears
in a green color, (this icon has an arrow pointing towards the left) and
select "Safely Remove Hardware".
The Safely Remove Hardware" dialog box will appear. Select "USB Mass Storage Device" and click "STOP"
On the next dialog box, click "OK" to remove the storage device.
On the next dialog box, select "CLOSE" and disconnect the USB cable from your computer.
Now you should be able to see the pictures on the digital photo frame.
Thanks.
My Grandma was given a
Most digital frames come with a USB cable to hook the frame directly up to a computer. When you plug in the frame, a drive should show up in your "My Computer" section (for Windows) or on your desktop (for Mac). In most cases, you just need to drag and drop the photos onto the drive.
How do you install photos from a jump drive on the
You
can move them to another card (i recomend a cheap usb stick) just move
from the camera card to a folder in your computer and then copy them to
the usb drive/stick and plug it in the picture frame
* Please rate this solution with Thumbs up and comment to help us improve providing support
