20 Most Recent Denon DN-V310 DVD Player Questions & Answers
  1. Turn the unit on
  2. Press the OPEN/CLOSE button
  3. Press CLEAR, 1, 4, 7, 0, CLEAR - "TEST MODE" will appear on the display.
  4. Press UP; "00 XX" (XX is a numerical value) will appear on the display. The first two digits are incremented by one, every time you press UP
  5. Press the UP key until you see "12 XX" (default is 24) on the display
  6. Press 2, 3, ENTER
  7. Press UP key again and you will see "13 XX" (default is 23). If it does not say "23", press 2, 3 on the remote and then the ENTER button
  8. Press the UP key again and you will see "14 XX" (default is 01).
  9. Press 0, 0, ENTER
  10. Press RETURN
  11. Press CLEAR twice
  12. Press RETURN ("END" should appear on the display)
  13. Press OPEN/CLOSE
Denon DN-V310... | Answered on May 11, 2011
laser lens may be defective or just needs cleaning
Denon DN-V310... | Answered on Apr 26, 2010
Don´t you put the progresive scan by mistake
Denon DN-V310... | Answered on Jul 08, 2009
For starters, the Chinese have a totally different set of coding than most anyone else. So you would most likely actually have to buy a dvd player out of China to read it. Otherwise, get teh right codec's for your computer to play it on a dvd rom drive for the computer. Im sorry that this may not be what you are looking for, but ive learned from buying a lot of foreign movies, that you most often have to buy the playing equipment also from the country to play it.
Denon DN-V310... | Answered on Mar 31, 2009
Appears to be a software problem. Unfortunately, some blu-ray players contain software that expires, requiring you to repurchase newer, more expensive software from the manufacturer in order to continue to play blu-ray discs. Check your software for the player. No freeware blu-ray software out there.
Denon Televison... | Answered on Nov 13, 2019
Open internal fuse or power supply failure
Denon Televison... | Answered on Sep 20, 2019
You can use a USB stick for region A, B or C. (1, 2 of 4)
On the USB stick there is one file named autoscript with the following : CLI(CLI_app.homemenu.set_bdreg 4). ,4 you can also use 1 or 2 this depends on the disired region.
Just copy this with textprogram and name the file 'autoscript'
T
1. Remove any discs from the drive of your player
2. Put the player into standby
3. Put the USB stick with the desired bluray region into the player
4. Turn on the player
5. Wait 5 seconds
6. Put the player into standby
7. Wait 10 seconds
8. Remove the USB stick
9. Unplug the mains cable
10. Unit should now be the region you have chosen for bluray
Before you do any firmware update, return to Region B as it may lock the region.hen do the following:
Denon Televison... | Answered on Aug 23, 2019
sounds like its stoping during layer switch, if the player is old its needs to be cleaned. its best to clean it once every 20hrs or so. if you do not have a disk cleaner you should go buy one first. if the player is new return it and get the best dvd player you can buy for any amount the toshiba xde. this player is phenomenal, the best you will be amazed. no i dont work for toshiba but ever since they started making hd dvd players(i know they stopped)there players have become the best. trust me if you dont think so just return it. no harm done. if you want a blu-ray get ps3 I dont like them either but i have to admit after buying (for movies only)my third blu-ray player it is by far the best one. almost as good as the toshiba on standard dvd playback but not quite. good luck.
Denon Televison... | Answered on Apr 17, 2019
Verify that the disc turns, put it in the tray, observe the position, enter it, wait for the indication of "No Disc" and remove the disc, if it is in the same place, apparently, it would have problems in the disc engine
Another way to check if the engine works, play an audio CD, if you read it, apparently the engine, it would not be the cause of the failure
If I notice that I turn, I could have dirt problems in the lens of the reader, proceed to clean it with a cotton swab and if you do not know how to do it, contact a technical service
Another option, it is possible that your reader is under power to read the DVD
Verifique que el disco gire, p?ngalo en la bandeja, observe la posici?n, ingreselo, espere a la indicaci?n de "No Disc" y saque el disco, si esta en el mismo lugar, aparentemente , tendr?a problemas en el motor del disco
Otra forma de chequear si el motor funciona, reproduzca un CD de audio, si lo lee, aparentemente el motor, no seria el causante de la falla
Si observo que giro, podr?a tener problemas de suciedad en el lente del lector, proceda a limpiarlo con un hisopo de algod?n y si no sabe como hacerlo, dir?jase a un servicio t?cnico
Otra opci?n, es posible que su lector esta bajo de potencia para leer los DVD
Denon Televison... | Answered on Apr 14, 2019
How do I reset my Denon remote?
All the settings are restored to their defaults. Press and hold RC SETUP for more than 3 seconds. "SETUP" and indicator flashes twice on the remote control unit. Use to display "RESET" on the remote control unit and press ENTER
Denon Televison... | Answered on Mar 08, 2019
If you have the Audyssey set up mic, plug it in and follow the on screen instructions. Or try installing the Denon AVR remote app.
Denon Televison... | Answered on Dec 26, 2018
Denon DN-V310 DVD Player Logo
9 questions posted
Top Denon Televison & Video Experts
Ekse
 Grubhead
Grubhead
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Denon Televison & Video
Most Popular Question
all cds or dvds placed in player receive
  • Televison & Video
