20 Most Recent
Garmin (010-00583-00) for nuvi 750/760/770 Questions & Answers
I am having problems downloading music on my Garmin Nuvi 760
what you can do is try and move the music onto the drive and not into a folder. Also if you are using a Garmin GPS then you cant download music because the type of device doesn't allow .mp3 files of music and it has its own music interface
1/10/2018 3:49:14 PM •
Garmin...
Answered
on Jan 10, 2018
NO SOUND ON GARMIN 750
I had the same problem. I fixed it by going to settings, then to language, and then entering American English into the Voice category. Hope this helps.
9/25/2014 10:10:21 AM •
Garmin...
Answered
on Sep 25, 2014
Cannot charge garmin in the car
I assume when your charging it out of the car you are using the usb port? Check the fuse in the tip of the car charger and if it is good, chances are your cradle is defective.This is a common problem with the 700 series. Check out GPSNSTUFF.com for cradles and chargers.
8/7/2014 3:41:03 AM •
Garmin...
Answered
on Aug 07, 2014
Garmin screen does not stay lit
Have you contacted Garmin they will be able to sort it or google your question if none of these suggestions work contact me
4/18/2014 7:21:32 PM •
Garmin...
Answered
on Apr 18, 2014
Won,t turn when plugged into
Check the cable that plugs into the unit itself. It possibly is damaged and will not acknowledge the GPS. Try replacing the car charger/ac adapter. Check NewPower99.com. they have a lot of inventory and great pricing. Good Lucl!
12/19/2012 7:38:13 PM •
Garmin...
Answered
on Dec 19, 2012
Garmin Nuvi 750 no sound
Under tools/settings/language check to make sure you have a voice with "TTS" after it, it means Text To
Speech. Make sure one of those are selected and see if it helps.
6/8/2012 3:32:06 AM •
Garmin...
Answered
on Jun 08, 2012
WHEN IN A TRAFFIC JAM, HOW DO I FIND AN
With the route showing on your satnav, press MENU and then DETOUR. This should take you around the traffic jam. Alternatively you could just turn off, drive a distance from the traffic jam and let the satnav update your route to get you back on track. I hope this solves your problem.
5/24/2011 10:39:12 AM •
Garmin...
Answered
on May 24, 2011
