20 Most Recent
Ingenico I6550 (6550US0041) Questions & Answers
Debit unavailable and credit is working
Call your Credit Card Processing company and tell them you need to have debit transactions enabled. They will need to update the software in your machine (you can't do it yourself). It will only take them a few minutes for them to fix.
When processing a debit card getting an error
You need to call your payment processor and give them this error code. Each processor has their own applications and error codes, it is not that the card is bad but something is not being transmitted correctly to them. Usually a quick fix once you call them.
Times out on debit
This would be your connection to the bank, something is wroung with the actually connection I would be on the phone with them and ask them to send someone out its free to have them come look at the unit as they benifit from your sales and you beifit from not having these problems.. There is not problem with the unit the pin is the next screen yes and it sticks before then yes okay that is because the transmission failed..
Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
HOW RESET INGENICO 3070
This usually means the pin pad has lost the injected programming. Ingenico may be able to repair it, but since they consider that the pin pad has reached it's end of life and been discontinued, they may not.
Ingenico i6550 units are loosing
This issue may be related to the GenPos application that you need to reconfigure. Try to download this particular application and run it on your system for stability DSIEncryptor.
GenPos update
Download the file and install. Tell me what happened.
