20 Most Recent
De'Longhi Magnifica Digital Super-Auto Espresso Machine ESAM3500.N Questions & Answers
De'Longhi PrimaDonna Soul Coffee Maker not making milk foam.
The milk delivery tube is very narrow bore and in my experience you will find the tube is blocked with congealed milk solids even if you clean then regularly. You need an enzyme milk cleaner like Rinza and even with that you need to manually massage the tubes or remove the blockages. The service engineers just replace them.
What does a CIMBALI M34 CODES ERROR 053 mean?
That .depends on software and configuration. It is not a universal code You might find help in the manual.
CIMBALI M34 SELECTRON USE AND INSTALLATION Pdf Download ' ManualsLib
Inspect Electrical Supply: Ensure that the machine is receiving proper electrical power. Sometimes, an interruption in the power supply can trigger error codes.
Clean Components: Check if any components related to coffee grounds or filters are dirty or clogged. Clean the underpan gasket, filter holes, and filter holder outlet hole.
Coffee Ground Quality: Verify that the coffee grounds are of the correct consistency. If they are too coarse or too old, it can affect the machine's operation.
Discharge System: Examine the discharge system for any blockages.
Why red light on senseo coffee machine blinks on one water level?
When the waterlevel gets high enough, a small magnet will float in a compartment at the bottom right, of the reservoir and give off the signal to a sensor.
Those floats either leak or corrode over time. What you describe can occur when it is pointing its magnetism in the wrong direction or even when it chooses to raise on its own terms. It is difficult to remove and replace those. Perhaps you can work the clamp loose, remove it and then fool the machine into thinking there is water, with another magnet attached. I have done it. You can see better if the float can be restored, when removed. Mostly it is both cracked open and filled with rust.
