20 Most Recent Crown XS1200 Amplifier Questions & Answers
My crown xs1200 won't turn on at all no lights showing at all when Turned on
If you are not seeing any indicators, you may have a fuse open, power transformer, bridge diode, etc, etc. When you first plug it in, do you hear any clicks coming from the unit itself? If you need more information, or would like to inquire about having your Crown repaired, please visit my website at audioserviceclinic.com. BTW, I worked for Harman Kardon. Crown is one of their products.
3/23/2015 5:28:43 AM • Crown XS1200... • Answered on Mar 23, 2015
Have a Crown amp xs 1200 that is in fault mode and
You may have two speaker wires touching eachother (shorted) or one of your speakers may have a fault and not giving enough resistance to the amp (shorted). Last option is that one power output transistor is damaged and appears to be a short circuit to the circuit protection system.
6/24/2011 8:48:13 PM • Crown XS1200... • Answered on Jun 24, 2011
I have two Crown XS 1200 and the fault light keeps
A common problem for these is bad capacitors in the power supply, Remove the back from your Amplifier and look at the power supply on the middle section of the amplifier
You will see bid round capacitor that are bulged / domed shaped on top usually these are valued any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same capacitor rating but a higher voltage.
Hope this help in solving the problem....
5/14/2011 11:31:37 PM • Crown XS1200... • Answered on May 14, 2011
Crown XS900 flashing Fault, Temp1, Temp2 5x when power is applied to IEC input. Nothing in owners or service manuals or from call to tech support.
I would study the service manual and service notes to find out why the temperature sensors do not work. Probably a supply rail down I would think to affect both of them.
3/25/2024 6:49:27 PM • Crown Audio... • Answered on Mar 25, 2024
Power Crown XTi 6000 activates protection and does not generate PWM what could it be?
The Power Crown XTi 6000 is a power amplifier, and it sounds like it is activating its protection circuit and not generating a Pulse Width Modulation (PWM) signal. There could be a few different reasons for this behavior. Some possible causes include:
  • Overheating: The amplifier could be overheating, causing the protection circuit to activate in order to prevent damage.
  • Short circuit: There could be a short circuit in the amplifier, causing the protection circuit to activate.
  • Input signal issue: The input signal to the amplifier could be causing the protection circuit to activate. This could be due to a problem with the source, such as a malfunctioning mixer or a disconnected cable.
  • Output impedance or load mismatch: The amplifier may have a mismatch in output impedance or the load impedance which can cause the protection circuit to activate.
  • Firmware or software issue : There could be a problem with the firmware or software that controls the amplifier, causing the protection circuit to activate.
Without more information, it's difficult to say for certain what the problem is. It's recommended to check the manual for troubleshooting steps and also check for any possible firmware updates. If problem persist it's recommended to take professional help.
1/17/2023 4:47:22 AM • Crown Audio... • Answered on Jan 17, 2023
3answers
Crown xli 2500 service manual needed .
Not most service manuals can be downloaded unless you use a model close to the original. Try service manuals.com
11/1/2022 11:57:14 AM • Crown Audio... • Answered on Nov 01, 2022
Crown CDi 1000 amp thermal on
Google should have a manual for your 1000 amp thermal and also try on the companies official website too for a manual. Try searching on YouTube as well and YouTube should have videos about amp thermal on - Crown Audio Players & Recorders
9/7/2020 6:18:53 AM • Crown Audio... • Answered on Sep 07, 2020
My crown xls 602 amp shut down when trying to turn on it won't reset
http://www.fixya.com/tags/crown_amplifier_fault
12/31/2018 10:03:03 PM • Crown Audio... • Answered on Dec 31, 2018
Crown amplifier xls402 fault indicator remain on and protection relay is not switching
If you have eliminated any shorted speakers, cables etc, then the only other cause is a shorted device on the power output board. Probably a device on the heatsink.
10/11/2018 7:41:35 PM • Crown Audio... • Answered on Oct 11, 2018
Did you receive my DVD of THe Crown Series one?
Hello, Sylvia - I have no idea what entity you meant to receive your question. You posted in the Fixya.com website, which is intended for asking and answering questions on how to go about REPAIRING THINGS. Plus, your question landed in the Fixya category for Crown (brand) Audio Players & Recorders. Perhaps you meant to message Netflix, or your local public library, or a person from whom you borrowed the DVD, or someone to whom you sold the DVD, or . . . Best wishes.
2/25/2018 5:41:37 PM • Crown Audio... • Answered on Feb 25, 2018
When I on my xti crown 4002 power amps,why the fan is not on,please help me,It just new after 3 days now..
Is the fan supposed to be on. On some units it runs all the time on others when the temp hits a certail level. Which is it for your baby?
9/4/2017 11:08:28 AM • Crown Audio... • Answered on Sep 04, 2017
When I turn on my crown xti2002 amp it won't stay on it powers off
It's best to assume there is a short circuit in the power amp board. The unit is going in to protect mode to stop it blowing fuses etc. Could be caused by bad speaker wiring or connections by the way.
12/2/2016 10:27:48 PM • Crown Audio... • Answered on Dec 02, 2016
Crown XS1200 Amplifier Logo
5 questions posted
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Mike Cairns
Mike Cairns
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Crown Audio Players & Recorders
Most Popular Question
two crown xs 1200 fault light keeps
  • Audio Players & Recorders
