20 Most Recent
Crown MA-5002VZ 2-Channel Amplifier Questions & Answers
Amp goes in and out of ODEP at will w/ no input or
Sadly, your problem indicates a circuit problem inside the amp. Either the protection circuit or the output stage is messed up. If you don't know how to get inside, best to get some professional help. Sorry there isn't better news on this one.
I hooked everything up on right the wireing and
Issue With Pre initial Rom Fail To Voltage Routine Check Cause... Static on The Chip Unit Posibility Security Relais Wont click On.. Do do so check for Fuse or red push botton over load security Braker at the back of your unit.. if your fuse is good Well Open the case and surch for more fuse inside of the unit Make shure the unit is unplug from the wall...Then check The voltage on the Transformer to make shure you have the right voltage then check The Regulator The Coil and Capacitor If your not shure Well send it to a Reapair Shop it your best choice Amp cant be dangerous for hazard shock....Good Luck
After i power on my
this does not have any effect on the Amp. There is a board in your amp that controls the IOC light. This board consists of ICs, Resistors, transistors and so on.
One among the ICs transistors, etc must have gone burnt as and that's why the light is dim or not showing fully.
There is nothing to worry about. You can continue using your Amp. Except in you want the light to show fully by all means but this does not have anything to do with the performance of the Amp.
If you desire, you can open the Amp, read the board the controls the IOC and change any component that has got burnt.
Best regards.
I have a Yamaha natural sound stereo amplifier
Try these for starters!
Is the power switch broke? Check the power cord! Are any internal fuses blown. Look inside for damage/burnt parts. Are the printed boards broken? after say being dropped? Is the transformer working? Check around the power supply area for faults.
Note - be careful your dealing with mains electric!
Interference
I think Radio Shack has a kit for this problem. Not sure about the cost, it's been awhile since I dealt with this problem. Good Luck.
Crown IT 4000 from ROMANIA
make cleaning to your filter by air blower------- keep good ventilation around in the pass of air(in-out)----after you finish try to test your amp by connecting one speaker only at a time until you find the bad one--------------if all above did not pass you will have internal problem of hardware and needs service center.
My amp doesn't turn on
take off all your speakers cables from amp and test if it is fixed you will have a problem in your cables or speakers itself-if not you have a problem in amp itself and needs to repair in service center.
Power Crown XTi 6000 activates protection and does not generate PWM what could it be?
The Power Crown XTi 6000 is a power amplifier, and it sounds like it is activating its protection circuit and not generating a Pulse Width Modulation (PWM) signal. There could be a few different reasons for this behavior. Some possible causes include:
- Overheating: The amplifier could be overheating, causing the protection circuit to activate in order to prevent damage.
- Short circuit: There could be a short circuit in the amplifier, causing the protection circuit to activate.
- Input signal issue: The input signal to the amplifier could be causing the protection circuit to activate. This could be due to a problem with the source, such as a malfunctioning mixer or a disconnected cable.
- Output impedance or load mismatch: The amplifier may have a mismatch in output impedance or the load impedance which can cause the protection circuit to activate.
- Firmware or software issue : There could be a problem with the firmware or software that controls the amplifier, causing the protection circuit to activate.
Without more information, it's difficult to say for certain what the problem is. It's recommended to check the manual for troubleshooting steps and also check for any possible firmware updates. If problem persist it's recommended to take professional help.
Crown CDi 1000 amp thermal on
Google should have a manual for your 1000 amp thermal and also try on the companies official website too for a manual. Try searching on YouTube as well and YouTube should have videos about amp thermal on - Crown Audio Players & Recorders
