20 Most Recent
Krups Nescafe Dolce Gusto Questions & Answers
Dolce gusto problem
In my case problem was dry/old electrolitic capacitor.Label on PCB - C2Value 470u/10V 105 degC
Why my Makita disc cutter has spark wont start
If the fuel in it is 2 or more months old dump it out and put in fresh fuel and try statring. Also try try a squirt of starting fluid into the carb. If it fires on it you may need to do this a few times to pull the old fuel in the lines through till the fresh fuel can get to the carb.
4/10/2024 4:13:02 PM •
Saws
Answered
on Apr 10, 2024
Clean grease off terracotta tiles
There are a couple of things you could try. I recently came across a specific grout/tile cleaner that works well. You can buy it online. It is a type of cream that you spread over the grease and leave for a while. After it has set, you can use a toothbrush (for best results) to scrub off the soap and grease. Otherwise, you can try magic eraser. Those can be used on tiles and get off a lot. Tiles make up such a great aspect of the house, I hope you can clean them up.
Elisa Jed '
http://www.herrmanntiles.net.au
12/2/2023 11:11:55 AM •
Saws
Answered
on Dec 02, 2023
