20 Most Recent
Hannspree Hanns.G HW191D 19 inch Widescreen LCD Flat Panel Monitor Questions & Answers
EARPHONES NOT ABLE TO PLUG INTO MONITOR.
Hi, I hope you've solved the problem. But if the first solution does not work for you maybe this one will.
I looked at the specs for your monitor. LINE IN is for plugging in a device that makes sound, so this is not the right hole (called a jack) for the headphones plug. Look on the back of your computer for a hole that is outlined with light green. You wrote that you removed " the audio wire that connects the monitor to the CPU", this would be the place to plug in the headphones.
11/22/2009 9:16:28 AM •
Hannspree...
Answered
on Nov 22, 2009
Need manual for Hannspree Monitor Xm-S
When you say the picture keeps dropping, is it going to the black or blue screen where it says it cannot detect an input/source?
If so that could be a faulty cable, if you have a spare cable to connect to whatever the input you're using is it would be worth trying that.
8/16/2016 11:20:28 AM •
Hannspree...
Answered
on Aug 16, 2016
How do you clear the cache on a hannspree android I pad
Hello and good morning,
To clear the cache of any Android powered device, there are a few ways. The easiest way is to download an app from the Play Store that has been written to clear the system-wide cache. One button press and you're done. Just be wary: some apps and games will reset of lose data if you clear they're caches, so be mindful when using a solution like this.
The other way is to tap SETTINGS, then STORAGE, and clear the cache from individual apps.
Hope this answers your question! For faster, personalized assistance, login to 6ya dotcom today!
5/5/2016 4:08:58 PM •
Hannspree...
Answered
on May 05, 2016
