20 Most Recent
Altec Lansing inMotion® iM500 Docking Station for iPOD nano Questions & Answers
Directions say it charges and syncs. When I
Look at:
http://www.speakerstation.co.uk/ipod-speaker-docks-ct-87.html
Important Note: iPods released since Sept 2008 (e.g.
Touch 2nd Gen, 4th Gen iPod Nano and iPod Classic 120 Gigabyte, iPhone
3g and onwards) have an updated dock connector that means older
revisions of speaker dock may not be able to charge these newer models
of iPod/iPhone. Older docks should play music from these newer models
with no problem.
The problem with charging is due to Apple
removing support for 12v (firewire) charging on these new models of
iPod/iPhone. Only 5v (USB) charging is supported on these new models.
The altec lansing inmotion does not charge my new
Maybe this could be the solution...
Source: http://www.speakerstation.co.uk/ipod-speaker-docks-ct-87.html
with no problem.
iPod/iPhone. Only 5v (USB) charging is supported on these new models. ..."
IPOD WILL NOT TURN ON
Have you tried holding the menu button down for about ten seconds? Make sure the hold button is not on.
Altec Lansing MX6021 Expressionist ULTRA 2.1
The "pluc pluc pluc" noise you're hearing from your Altec Lansing MX6021 Expressionist ULTRA 2.1 speakers could be a sign of a few different issues. Here are a few things you can try:
- Check the cables: Make sure all cables are connected properly and there are no loose connections. Try using a different cable to see if that solves the problem.
- Check the power supply: Ensure that the power supply is plugged in and working properly. Try using a different power outlet or power supply to see if that solves the problem.
- Check the volume: Make sure that the volume on your device is turned up and the speakers are not on mute.
- Try a different device: Connect the speakers to a different device to see if the issue is with your laptop or the speakers.
- Check for software updates: Visit the Altec Lansing website to see if there are any software updates or firmware updates available for your speakers.
If none of these solutions work, it may be time to consider contacting Altec Lansing customer support or a professional audio technician for further assistance.
