20 Most Recent Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G Questions & Answers
I have a dell inspiron
Some computers do not come with dvd software installed.Do you have a dvd drive installed?If no software for dvd installed you can also use windows media player or realplayer to play dvds.Click start button,control panel then autoplay.Under dvd movie choose player you like to use and click save.Try inserting dvd again to check for playback.
6/3/2020 3:26:51 AM • Dell Inspiron... • Answered on Jun 03, 2020
4answers
I insert a DVD into my Dell Inspiron 530S and it
hi
insert another dvd. if same happens then restart the computer and try once more .
..again fails please reinstall the driver or shutdown the computer .
open the cabin unplug and reconnect the code to dvd drive
hope you do it...
11/7/2019 3:20:16 AM • Dell Inspiron... • Answered on Nov 07, 2019
What is the productivity tool
the world may never know
2/16/2015 8:41:15 PM • Dell Inspiron... • Answered on Feb 16, 2015
2answers
Physically can't plug into front usb ports on new Inspiron 660. port will not accept the plug,
I've only ever come across this once before as a technician, and it turned out to be the board, with the ports mounted on, not being set in quite the right place on the inside of the front pannel. I only had to push the board and it located. Hope this helps you.
1/31/2015 6:21:18 PM • Dell Inspiron... • Answered on Jan 31, 2015
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
12/7/2014 8:14:05 PM • Dell Inspiron... • Answered on Dec 07, 2014
The computer will boot up randomly with no assistance. Also doesn't boot right into Windows (must hit F1).
Could be a feature in the bios or a virus. I would do some research on the matter. If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_70466cb634a57543
11/26/2014 12:59:53 AM • Dell Inspiron... • Answered on Nov 26, 2014
Recently acquired a Dell Inspiron 530s, having 2 problems. First, it won't boot right into Windows (Vista), asks to hit an F key (after hitting F1, it goes right into Windows). I went into Setup and a
It's a 'failsafe' - You will need to go back into the BIOS - double check the boot settings - and verify the HDD is set to Auto - make sure the RAM installed is the RAM shown on the boot screen. Ok, once that is done reboot 2x - hit no keys - if it request F1 to continue, CTRL/ALT/DEL reboot. - go into BIOS, go to boot options find the part that states "stop on error" and disable that... reboot. If that doesn't help Contact me here. I've other solutions to try as it is a DELL and I've dealt with them for years.
11/25/2014 7:47:43 AM • Dell Inspiron... • Answered on Nov 25, 2014
Password unknown
FYI, I know this is an old posting but you don't have to go to Dell Tech Support for password reset, just reset the CMOS password jumpers inside the computer. Not a difficult task at all, refer to the owner's manual for details on opening the computer, and for resetting the jumpers. Very easy solution, did it myself. Hope this helps.
8/22/2014 4:02:56 PM • Dell Inspiron... • Answered on Aug 22, 2014
System restore from a command prompt
type ....scanreg/restore...Enter....select Date, choose restore
8/1/2014 6:04:24 PM • Dell Inspiron... • Answered on Aug 01, 2014
Can i fix a dell desktop computer
Your question is unclear. What signal? What is rga? Tell us what the computer is doing, or not doing if you want an answer.
7/29/2014 9:29:21 PM • Dell Inspiron... • Answered on Jul 29, 2014
HOW TO FIX THE MOTHERBOARD ON 530S DELL INSPIRON
Cheaper to buy to new computer.
3/23/2014 10:48:57 PM • Dell Inspiron... • Answered on Mar 23, 2014
Computer won't turn on
It sounds like one or more RAM modules are bad. Try taking them out and test one at a time.
2/4/2014 1:59:36 AM • Dell Inspiron... • Answered on Feb 04, 2014
Connection for powered speakers from a Dell 570 Desktop.. What colours are the R and L female phono sockets ?
They are usually colored coded. Pink to Pink, Green to Green, etc..
11/2/2013 12:51:04 AM • Dell Inspiron... • Answered on Nov 02, 2013
My computer is stuck in sleep mode and it says to touch any keys or move the mouse, i did and nothing is happening, i have restarted and same thing. just a blank screen. please heklp
turn off computer and remove power cableand reconnect power on by pressing F8 go in to SAFE MODE REMOVE ANY TEMP FILES RESTART MAY FIX UR PROBLEM
10/30/2013 10:34:46 AM • Dell Inspiron... • Answered on Oct 30, 2013
Greetings, My Dell Inspiron 530S has a small
I did not look up the manual for this one. But most computers have a flashing light when the hard drive is accessed. When the drive is accessed you can hear it to. So looks to me you have a good working computer. If the sound of a hard disk is loud, you are in trouble. You should start making backups of everything if you did not do that before. If it is really just the fan, you should clean the fan and the inlet (outlet) of the airflow. most fans will accumulate dust and that will influence the warming up of the processor (your Dual-core E2160) causing the fan to run faster and faster, not capable to cool the processor enough. Often you can blow out the dust, without opening the computer, but if there stays dust in the commuter and you are not technical enough, please ask a technician to clean pup the compete airflow.
10/28/2013 11:30:46 PM • Dell Inspiron... • Answered on Oct 28, 2013
NOT SURE WHAT IS WRONG, BUT IT STARTS UP OKAY,
this sounds like an issue either caused by a virus or corruption in the login process of the OS, are you able to start the PC in safe mode ?(f8 at startup) I’m happy to help further over the phone at https://www.6ya.com/expert/michael_2ebcd3cbc4810dbf
10/7/2013 9:39:28 PM • Dell Inspiron... • Answered on Oct 07, 2013
Retrieving administrator settings
Click start Control Panel.
Select "User Accounts and Family Safety," then "User Accounts."
Click "Turn User Account Control on or off."
Remove the check mark next to "Use User Account Control (UAC) to help protect your computer."
Click "OK."
Set All Accounts to Administrator
Still in the UAC section of Control Panel, select "Manage another account," and click on a user account.
Click on "Change the account type." When working with multiple accounts, some changes can only be made if you and the account holder are both logged in with "Administrator" accounts so you need to change all user accounts to "Administrator."
When you are done making changes, you can change them back to "Standard," but always leave at least one "Administrator" account.
Select the "Administrator" radio button.
Click "Change Account Type" at the bottom right.
Repeat this procedure to change each user account to "Administrator." When all user accounts have been changed, close the Control Panel.
Create a Full Administrator Account
Click "Start" (the Windows Vista icon in the lower left of your screen). In the Search box, type "cmd". Right-click on "cmd," and select "Run as Administrator." An elevated command prompt window will appear.
At the command prompt, type "net user administrator /active:yes", and press "Enter."
Choose a password and assign it to the "Administrator" account, by typing "net user administrator 'password'", where 'password' is your selected password. For instance, if your password is "abc," type "net user administrator abc". Press "Enter."
Type "exit" and press "Enter."
Log off. When you log back into your "Administrator" account, you will have full rights.
hope this helps
8/6/2013 11:35:55 PM • Dell Inspiron... • Answered on Aug 06, 2013
Remove or reset Dell inspiron 530s bios password
try this:1- shut it down then open the computer box2- find a green or blue jumper beside the memory slot or Data cable slots3- remove jumper , then turn computer onwait for 10 sec then shut it down4- put the jumper back and close the computer box5- turn the pc on and have fun
8/3/2013 1:10:58 AM • Dell Inspiron... • Answered on Aug 03, 2013
How do I return "Add a program" to the Control Panel under Programs?
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7 and windows 8 once you open the mouse you will see mouse and keyboard center link mid page click on that to change your mouse right click in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar Click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver Click on >> control panel all control panel items mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp. In windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp Hope this helps.
12/29/2012 4:57:48 PM • Dell Inspiron... • Answered on Dec 29, 2012
Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G Logo
Popular Tags
206 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
Inspiron Dell
  • Inspiron Dell
Most Popular Question
connect bluetooth device card pc dell
  • Computers & Internet
