20 Most Recent
Utilitech 3/4-HP 15 GPM Shallow Well Jet Pump 3/4-JET Questions & Answers
Low water pressure how do i increase the pressure
The water pressure is adjusted with the pressure switch, which turns the pump on and off. The pressure switch is typically set for a cut-in and cut-out pressure of 20-40 psi, or 30-50 psi. Usually there are adjustment directions on the inside of the switch cover. But, there are several other factors that may affect the house pressure. If there is a pressure tank that is pre-charged, the tank pressure may need to be reset, or the tank bladder may be ruptured. Have the entire system checked out.
How to turn on
Need to know at what stage of the pump installation you are at.
Will not prime
My pump didn't pump until I filled the 'suction side' pipe with water before I attached the pipe to the pump. The suction pipe needs a foot valve if you have a long lift from the water to the pump. Then pour water into the pump on the outflow side. Should pump fine . It'll purge the air out after a little bit if you filled the pump with enough water. I almost bought a relacement pump but then realized that the foot valve wasn't sealing and the suction pipe wasn't holding water. We have about a 8 foot vertical draw to the pump . Good luck.
New utilitec pump cuts on and off, won't hold pressure
I do not know your system however it sounds like it is on a well system. If so the pressure tank is water bound and needs to be drained. There is a air regulator that needs repair or replacement. I am just taking a guess.
8/18/2014 10:39:13 PM •
Utilitech...
Answered
on Aug 18, 2014
I have a pump #WO313834UTPQP1W
Hi Tata,
There is no match appearing across the web for that identification number of your pump. There may be character missing or swapped. Please verify the support information.
Here is a link offering the pumps at replacement cost which may be more viable looking at the price and effort you may invest in the repairs. Take a look.
utilitech parts for pumps BuyCheapr com .
At the bottom of the page above, a variety of options exist. Below is one of them
Here is a resource further in on the first sight to examine
Top Results for pump parts
Happy wrenching. Fare. Well.
6/25/2014 7:57:59 PM •
Utilitech...
Answered
on Jun 25, 2014
