20 Most Recent Norelco Advantage 6705 X Electric Shaver Questions & Answers
Dead batteries
You will find batteries for model 6705X at shaveroutlet.com. See link belowhttp://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.htmlScroll down item page for viedo tutorials for installation tips
12/2/2014 10:50:54 AM • Norelco... • Answered on Dec 02, 2014
I have a new Norelco shaver with the regular 3
For a helpful video showing how to install the heads, see the link below from shaveroutlet.com then scroll down for videohttp://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq167-cool-skin-replacement-heads-p-247.html
12/6/2011 10:58:42 PM • Norelco... • Answered on Dec 06, 2011
What are the buttons on either side of the
The yellow buttons on model 6705X are used to dispense the Nivea skin lotion that is a feature of this model. The lotion cartridges are for sensitive skin and are inserted on the back of the shaver.These lotion packets can be found at shaveroutlet.com at the link belowhttp://shaveroutlet.com/shaver-accessories/norelco-hq170-cool-skin-nivea-lotion-5pack-box-p-261.html
12/6/2011 10:55:46 PM • Norelco... • Answered on Dec 06, 2011
Unit does not take charge. sits on charger normal
Most likely, the battery is dead and needs replaced. You will find the correct battery type at shaveroutlet.com. See link below
To replace, start by removing the lotion packet cover on the back. Then remove the 4 screws to remove the battery compartment cover and access the batteries. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
1/24/2011 2:58:36 AM • Norelco... • Answered on Jan 24, 2011
Razor wont charge
Yes, the batteries can be changed. You will find replacement batteries for model 6705X at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
To change the batteries, you will need to remove the lotion cartridge cover on the back and then remove the screws on the back of the inner cover. Remove the back to get to the inside of the shaver. The batteries are soldered to the circuit board. You can unsolder them or it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs. Reassemble in reverse order
If you are not able to do this repair yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
6/10/2010 4:17:30 PM • Norelco... • Answered on Jun 10, 2010
0answers
Need to replace the lotion dont know how
Don't use the NIVEA lotion, just coat your face with a sensitive skin shaving gel, like Edge or Gillette, then run the shaver over your face. The shave is much better and cheaper. I gave up on the NIVEA packets over three years ago.
5/6/2009 2:40:46 AM • Norelco... • Answered on May 06, 2009
Norelco 6735x trimmer head
Just pop up the top with the cutters. Next pull the cutters from the shaver in the back prongs. Insert the trimmer head and reverse operation when you are fiished. [email protected]
3/27/2009 11:32:14 PM • Norelco... • Answered on Mar 27, 2009
Replacing batteries in a 6705x norelco shaver
To open up your shaver, remove the lotion cover and remove all 5 screws with a small flat head screwdriver. They have a star head, but also a flat notch. Since they shaver is water tight, the first time you open it up it will be difficult, but if you pry off with your screwdriver it should pop off.
Towards the head of the shaver the batteries are soldered to the circuit board. Pull the tail end of the batteries out of the plastic holder and cut them at the top end as close to the batteries as you can, or CAREFULLY bend it back and forth to snap the metal. Dispose of the batteries responsibly as you would any batteries.
Hope it helps you.
1/7/2009 11:27:35 PM • Norelco... • Answered on Jan 07, 2009
Go to this link
you can find it.
1/7/2009 8:38:15 PM • Norelco... • Answered on Jan 07, 2009
Norelco shaver won't turn off
You should check the switch behind the batteries. You likely dislodged the piece of plastic that presses on the switch. It's simple to place back properly--if that's what the problem is.
8/8/2008 3:41:57 PM • Norelco... • Answered on Aug 08, 2008
3answers
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
4/21/2008 7:40:18 PM • Norelco... • Answered on Apr 21, 2008
Won't charge up, won't run
uh...the charger's supposed to have a DC output
3/11/2008 2:33:01 PM • Norelco... • Answered on Mar 11, 2008
2answers
Norelco doesn't work
Open the screws and replace them
3/4/2008 3:07:16 PM • Norelco... • Answered on Mar 04, 2008
2answers
Battery replacement
1/4/2008 10:02:21 PM • Norelco... • Answered on Jan 04, 2008
Battery replacement
The batteries are just 2 rechargeable Ni-Cd AA's, soldered together at one end to form a connection. I popped in two regular AA batteries, formed a connection between them, and it started spinning again!
1/4/2008 7:20:42 PM • Norelco... • Answered on Jan 04, 2008
2answers
Battery replacement
is there a sticker at the back of shaver? try to checkout the hole at the sticker, that is the screw, or you can open the unit by unlocking the side locks by cliping out the locks!
10/10/2007 8:40:38 PM • Norelco... • Answered on Oct 10, 2007
Norelco Advantage 6705 X Electric Shaver Logo
Popular Tags
29 questions posted
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Norelco Health & Beauty
Most Popular Question
razor wont charge
  • Health & Beauty
