20 Most Recent
Tiger JAE-A10U 5..5-Cup Rice Cooker Questions & Answers
When i plugged my cooker in the numbers started
I am having the same problem. Here is what the Tiger people say. I haven't tried it yet though.* If an external power failure has occurred, but only for a short time, then there's a possibility that when the electricity has returned, all functions may work normally and the clock is working correctly.* When a power failure lasts for a long time, and the indicator is flashing 0:00...--> Please set the time correctly by following the instruction manual.If the electricity has returned as in these situations below:(If it's already past the set time, after a lengthy power failure, cooking starts immediately.)* While cooking rice (or reheating rice).--> Continue to do the cooking (or reheating).* Keeping warm (or Low temp Keeping warm).--> Continue to keep warm (or low temp Keeping warm).
My Tiger Rice Cooker did
wiring problem, carefully open the bottom side of unit, check all wiring for loss connections. unscrew everyone bolt then check wires carefully.. if done try it..if not work' .bring your unit to the nearest qualified technicians.
How much water for brown rice
Typical, 1 cup of brown rice will need 2 and 1/2 cup water. Then depending on type of brown rice and your taste ( chewy or soft..) you can adjust less or more water to go from then.
You are probably hearing Japanese cup is 6OZ and US cup is 8OZ, but it doesn't matter if going by ratio as indicated above.
