This may not be feasible. You will need to first get the nameplate data off the engine. Go to their website and search the parts pages. The flywheel may not have teeth on it first of all. Typically not for most small pull start engines. The block also may not have the necessary machining and tapping to mount the starter. Also it may not have a charging coil and regulator to recharge your starting battery. If you get that far.
JustAnswerhttps://www.justanswer.com > small-engine > 4e3fa-hu...
Dec 29, 2010 - Let me know what you find, and we will continue of if need be - but the single most common issue with these sets, by far, is a bad voltage ...
1 answer ยท Top answer: Ok, here is what you need to do next. Please read these instructions carefully, and do the ...
