20 Most Recent
Linksys WUSB100 Wireless Adapter Questions & Answers
Just a quick question? can
I'm going to assume you are using a wireless router, and are trying to figure out how to change what channel you connect to it on.
All you need to do is change the channel on your wireless router, and the adapter will automatically connect on that channel.
-Snack
Added a linksys wusb100
Check to make sure that you don't have any cordless phones in the area or ductwork directly below your computer between the adapter and the router.
Trying to connect to my
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Need driver for Linksys WUSB100
Go to www.linksys.com they got every driver for their products. Make sure you get the driver for the operating system your using.
Thanks
Is it compatible with mac
Yes it is compatible with Macintosh. Did you need anything else I can help you with? Did you need the driver for it?
Wusb100 has poor signal and is new
U r facing the same issue which my bro was facing ,
Well the problem then is not from ur adapter its from ur router ...
Just increase the channel width and the channel on ur router ...
if it still doesnt work uninstall te adapter and install its once again ...
Thank u ...
My wireless connection cuts out about every 15
Does it happen on all wireless computers? Try playing around with the channel on the router. Make sure that you're not near by a cordless phone or microwave that will interupt the signal. Play around also with the antenna on the router.
Aquiring network connection / Low connectivity or no connectivity
just asked the similar question as mine searches for automatic preferred network it says it is out of range while again I have 98 per cent on wireless it refuses which has the right code and detail we set up. So at least if you watch my answer to posted help maybe that will answer yours. Amilo notebook Atheros system but this may be a common to others listed as Fujitsu Amilo notebook Atheros AR5005G ... I know how they should work but Motorola had nightmares with this as did Vodaphone when I wrote them a graphics programme 1989 1990 as a short term (carphones), my work is hydrology soils Geology but I was taught Lotus macros by a great lady at Employment Initiatives as I never learned Algol and Fortran fully (punch cards days of JANET) and spent 20 years of success with hardly a computer in range except processing my salary and tax, which is where I wish I was now. Right have a look and get a free result, they may resolve both at once ... mine has a nine point code I do not recognise. I cannot disable and it worked right first day Broadband and after 78Mb updates it collapsed. Mike
