20 Most Recent Navigon 5100 GPS Navigator Handheld GPS Receiver Questions & Answers
Try contacting navigon direct, or search the site on e-bay.
Navigon 5100 GPS... | Answered on Dec 02, 2015
You must edit port and baud rate in sys file. If dont know parameters just write:
[gps]
port="auto"
baud="auto"
Navigon 5100 GPS... | Answered on Oct 17, 2014
I own a GPS also and I dont know of a GPS that a consumer can buy that would cover that much area.So I researched it a bit for you to help you out. Click the link or copy in to your web browser. You will see that you need additional maps for the area of the US you are in. I would contact them first before you purchase any maps just to make sure your unit does work in the US. There is support info also listed on the site. Here is the link:
http://www.navigon.com/portal/us/buy_now/mobilenavigator.html
I hope this help you out, if it does please leave me a YES that I did try to assist you. Thank you.
Navigon 5100 GPS... | Answered on Apr 09, 2011
If the contacts are still intact .just use a strong glue for plastic and glue it in place on the board..If it was on direct contact with the board and now i do not have any contact with it (wires) you will have to identify the contact points and wire it first .In short if there seam not to have any assembly ..it means that it was glued on the case or the main board..and just glue it back ..either on the board or the case...
Navigon 5100 GPS... | Answered on Jan 17, 2011
Had the same problem with Navigon for the iPhone. I found a simple quick fix:
1. Go to your iPhone Settings
2. Press the General tab
3. Scroll to the bottom and press the Reset tab
4. Press the Reset Network Settings tab
This may take a short time, then after it's done, reboot your device (if it doesn't on its own).
You should now have a good GPS signal!
Navigon 5100 GPS... | Answered on Jun 19, 2010
my tomtom Go 720 stays frozen. When I try to push the "I agree" button it stays frozen.
Navigon 5100 GPS... | Answered on Mar 28, 2010
Here you can download the user manual for your Gps.
Click HERE
Hope this helps
Navigon 5100 GPS... | Answered on Nov 23, 2009
I am using Navigon on the iphone cant get a GPS signal please can you adv
Navigon 5100 GPS... | Answered on Oct 11, 2009
3 things and 1 is serious
Not a clear view of the sky...
Batteries are too low to read a satellite signal fully charge the unit
The SIIRF chip is damaged.. Expensiive!
If you put it into car power and start engine it will damage the unit and one day you will turn it off and then on and it will never work again
Better hope its just a low battery
Please rate our help to keep FREE service online
Navigon 5100 GPS... | Answered on Aug 30, 2009
I'm not sure if you realize this, but you must hold the power button for about 10 seconds to turn the 5100 on and off.
Navigon 5100 GPS... | Answered on Jul 15, 2009
when ever i staet computer i get line0 and error unable to access external programm, what is the solution.
it works ok after cancelling the message
Navigon 5100 GPS... | Answered on Jun 14, 2009
NAVIGATION IS NOT WORKING. THE SCREEN IS " NAVIGON AND THE WORLD IS YOURS"
WHAT IS THE SOLUTION.
Navigon 5100 GPS... | Answered on May 19, 2009
Navigon 5100 GPS Navigator Handheld GPS Receiver Logo
Popular Tags
35 questions posted
Top Navigon GPS Experts
Marvin
Marvin
Anthony Ward
Anthony Ward
Are you a Navigon GPS Expert? Answer questions, earn points and help others
View Most Popular
Navigon GPS
  • Navigon GPS
Most Popular Question
after installing igo navigon no gps
  • GPS
